Page: |
Home > A-Series EFI / Injection > On to Microsquirt ignition options | |||||||
186 Posts Member #: 7637 Advanced Member Fremont California |
5th Feb, 2014 at 06:38:13pm
I also need a solution to ignition. I had planned to keep the Rover components and form factor because I know it fits in the engine bay without too much modification, but there could be other reasons to not use the original Rover style coil in wasted spark configuration.
Edited by tmsmini on 5th Feb, 2014. |
5th Feb, 2014 at 06:46:06pm
Paul S did, but the pics dont seem to be working at the moment.
5th Feb, 2014 at 06:56:19pm
I've used the LS style coils on 3 of my engines:
5th Feb, 2014 at 07:22:33pm
On 5th Feb, 2014 Paul S said:
You will need to wire them wasted spark with the Microsquirt though. That may raise issues that I'm not aware of. Actually, he's not using a cased Microsquirt but a Microsquirt module based ECU which does have 4 ignition outputs. So the only restriction for having sequential ignition is the need to use a cam sensor. |
5th Feb, 2014 at 07:26:14pm
Great, thanks for the photos.
5th Feb, 2014 at 09:21:43pm
looks like stevieturbo found the integrated coil/ignitor a few years ago on a different forum...did you ever use it? |
6th Feb, 2014 at 05:13:14am
So this one from various VW and other cars looks like a good fit:
6th Feb, 2014 at 07:29:02am
Re. the plug, hard to tell from the photo of the coilpack but I wouldn't be confident the one's you have linked would be correct for a VW part from personal experience of another VW part (or at least a very common fitment on VWs).
Edited by Rod S on 6th Feb, 2014. Schrödinger's cat - so which one am I ??? |
6th Feb, 2014 at 02:36:23pm
Understood Rod. Pictures are hard to positively identify.
6th Feb, 2014 at 03:13:24pm
Terry,
7th Feb, 2014 at 02:01:14am
Looks like I need to try VW as both auto parts suppliers I tried on the way home from work did not even have it listed.
Edited by tmsmini on 7th Feb, 2014. |
7th Feb, 2014 at 03:33:52am
That part number looks good, on Google UK it comes up as a VW 6 way connector housing.
Edited by Rod S on 7th Feb, 2014. Schrödinger's cat - so which one am I ??? |
7th Feb, 2014 at 02:39:38pm
In case anyone else is interested this is what I found on the coil so far:
7th Feb, 2014 at 03:23:20pm
On 7th Feb, 2014 tmsmini said:
Would still like to get the pinouts and specs for the coil. A quick Google on the UK sites suggests pin 1 is ground, pin 6 is 12V, and the ones inbetween are the triggers. BUT..... I would seriously suggest getting a copy of the VW wiring diagram off eBay to make sure. They only cost a couple of GB£ over here and that coilpack seems very expensive in the USA to risk damaging it (they are actually quite cheap over here but I guess that's because VW/Audi group are EU). Schrödinger's cat - so which one am I ??? |
7th Feb, 2014 at 04:47:01pm
On MSExtra I found a link to the Hueco site and using their VW cross reference I found this. It is attached. It may be old, but seems to be the same model.
7th Feb, 2014 at 05:03:18pm
So I am assuming with 4 ignition inputs, this could be triggered sequentially, but also in wasted spark by linking inputs?
7th Feb, 2014 at 05:12:53pm
So I am assuming with 4 ignition inputs, this could be triggered sequentially, but also in wasted spark by linking inputs? That's correct. |
8th Feb, 2014 at 02:05:48am
Purchased another connector from a VW dealer today, US $10. It will take a day or two to get here. So US $45 for the coil and $10 for the connector. I have extra pins and seals for the other JPT connectors. |
8th Feb, 2014 at 11:01:00am
That's a very good price, best I could find over here is £40 (so about $65?) for the coilpack. Connector I haven't asked yet but the 5 way one was only £3 from a VW main agent so probably similar for the 6 way but, overall, a nice price for anyone over here wanting to run fully sequential ignition without using COP or CNP.
12th Feb, 2014 at 03:41:08am
It is not perfect, but it looks like it will fit. I may need to make a mounting plate.
Edited by tmsmini on 12th Feb, 2014. |
13th Feb, 2014 at 09:24:48am
Just spotted this on the MS-E site
Edited by Rod S on 13th Feb, 2014. Schrödinger's cat - so which one am I ??? |
13th Feb, 2014 at 11:30:59am
I like the VW logic level coil option. Much tidier than the LS coils which are a bit overkill to be honest.
13th Feb, 2014 at 12:51:11pm
On 13th Feb, 2014 Paul S said: Agreed,
I like the VW logic level coil option. Much tidier than the LS coils which are a bit overkill to be honest. Good find. I've ordered one to play with (I can re-configure one of my spare MS2s for sequential ignition) and some connectors. Coilpack was £39.99 posted and connectors were just under €2 from a VW supplier in Germany, which worked out at £12 for three posted with German Sales Tax (no import duty as it's EU but you pay their VAT rate instead of ours). I ordered three to make the cost of the connectors match the postage but £6 postage is still less than the cost of diesel to drive to my nearest VW main agent. I mainly want to see if they operate on 0V or 5V (as the draft Microsquirt manual is confusing) and how big a gap they will jump compared to the Ford coilpack. Schrödinger's cat - so which one am I ??? |
13th Feb, 2014 at 03:12:43pm
Rod,
13th Feb, 2014 at 03:38:39pm
Thanks Jean,
Page: |
