Home > A-Series EFI / Injection > megajolt troubles, urgent
miniminor63
Member #: 672
The oversills police
Oslo, Norway
Hi, I know this really is not the correct forum for this, but as the picasso forum is so slow, i will try...
here goes:
Im going on the rollers tomorrow morning, and suddenly my megajolt dont want to communicate with my computer anymore....
I have a shitty troublesome usb/serial adapter on this computer. so have aquired another computer with a real serial adapter. will try this later when I get home from work. but this have java 1.5xxx. will the javacom downloaded from the megajolt site work as good with this(meant for 1.4xxx?) with the files in the same folders?
I need a modemcable and not a NULLmodem cable right?
I really do not understand why it suddenly do not want to communicate, but will troubleshoot until the solution is found. Any ideas?
the adapter pointed as com1 (the one used in the tuner software for me now), and also power was on.
Edited by miniminor63 on 27th Jun, 2006.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
any version of java newer than 1,4 is fine,
you need a mouse extension cable :)
NOT a serial cable.
Alex
AlexF
miniminor63
Member #: 672
Oslo, Norway
okay, so its the same javacomm package for 1,4 and 1,5?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I run the latest one with no problems :)
Alex
AlexF
have you tried using the latest software? it can be found by looking on the forum done by 4600cc, its much better
hmm otherwise try changing the ports, mine messed up on me the one day but after flicking through the different ports and changing it in device manager its been fine
colas
Member #: 102
Pennsylvania USA
I use that one by 4600 aswell. Its much nicer. No messing with java. just download and install and it works fine.
I use the serial cable. I tried a modem cable but it wouldn't work. Apparently in has to be pin 1 to pin 1 all the way to pin 9. Null modems have some pins reversed I think.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
thats sorrect colas...
a mouse extension cable is just that .... pin 1 - pin 1 though pin 9 - pin 9.
IE perfect.
Alex
AlexF
