Home > A-Series EFI / Injection > Mega Jolt Lite
fester
Member #: 674
Gympie, Qld Australia
Guys I know this is not quit ethe forum for this topic but searching Google so far has not yielded me the result I'm after.
Can anyone point me to a site that covers the topic for the A Series but just for ignition not EFI.
I have another motor that I want to retain high compression and carby and would like to have programmable ignition.
So far I haven't been able to find any sites with a forum section that covers that.
Gavin
colas
Member #: 102
Pennsylvania USA
http://picasso.org/mjlj/
fester
Member #: 674
Thanks colas but I've been to that site. Was after one that might have covered A Series istallation and mapping in detail though.
Nic wrote a guide on this forum
http://www.turbominis.co.uk/forums/index.p...&tid=5741&fr=25
There is also loads of other info, search for Megajolt and plenty of threads should come up.
curta_crankn_daddy
Member #: 799
Canada, eh?
On 25/06/2006 02:38:15 fester said:
...Was after one that might have covered A Series istallation and mapping in detail though.
Mapping ingnition on an A series is no different from mapping any other engine. Just start with the mechanical advance curve, project it over the full load range, then add your vacuum advance table on top of the low load area. From there, put the engine on a dyno, ask it what feels good and modify the map to suit. When you're done, smooth the surface so it doesn't look like a mountain range then you're done!
www.starchak.ca and www.TDCperformance.ca
