Page: |
Home > A-Series EFI / Injection > MPi Turbo, with piggyback MS | |||||||
4559 Posts Member #: 786 Post Whore Bermingum |
30th May, 2006 at 10:23:06pm
30th May, 2006 at 11:08:57pm
Now that we have established that the MPi wheel is a 36-4 pattern, I have to say that there is no current MS version that will handle that. Like I said in another thread the upcoming MS2 code will handle that but I can't say when it will be ready yet.
30th May, 2006 at 11:23:37pm
Edited by Bat on 30th May, 2006. VEMs Authorised Installer / Re-seller. K head kits now available!
30th May, 2006 at 11:52:47pm
You have to be careful about what's actually available for you. If you're not fully controlling fuelling with MS, you are limited for certain options.
30th May, 2006 at 11:53:07pm
Edited by Bat on 31st May, 2006. VEMs Authorised Installer / Re-seller. K head kits now available!
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
31st May, 2006 at 01:57:49pm
Good luck with the MPi box, the gearsets seem to be made of cake........
397 Posts Member #: 694 Senior Member Shropshire |
1st Jun, 2006 at 12:21:18pm
On 31/05/2006 13:57:49 Tom Fenton said:
Good luck with the MPi box, the gearsets seem to be made of cake........ Couldnt agree more 59,000 miles and two gearboxes later :( |
1st Jun, 2006 at 03:15:06pm
On 30/05/2006 23:53:07 Bat said:
Do I have to use EDIS or will MS run a coilpack and 2 injectors directly? Cheers, Gavin :) You don't have to use EDIS. MS will run a coilpack but it will require a small modification to do so. It's all explained on the MS1/extra site. I was just mentioning that this is another option but I would recommend using direct coil control for the ability to do spark-cut. Jean |
Page: |
