Home > FAQ / Knowledge > T2/25 on Metro Turbo Manifold
On 23/05/2006 21:55:39 TurboDave said:
http://www.netsnapshot.com./pcw/buildalbum...=2&ACCOUNT=4541
1) Cut off studs.
2) linish manifold face flat
3) Purchase adaptor plate off Jimster
4) Wait 3 months for him to get round to posting it
5) Upon arrival, place on manifold in orientation shown in above pics
6) Mark out holes for the T2 bolt pattern on the manifold
7) Drill and tap the holes M8
8) Purchase Stainless M8 Studding, a pack of M8 stainless nuts and washers from Screwfix.com
9) Wind studding into manifold
10) cut off studding to appropriate length
11) wind some nuts down the studs and hold the plate securely to the manifold
12) Port the plate and manifold to promote decent flow into the small T2 opening. Remove plate and port 'back' the port dividers if needed.
13) Trial fit turbo.
14) If it's off the R5GT, you need to remove two studs and open the holes out to M8 clearance holes (9mm). You also need to make room for a nut on the tighter corner (this'll become obvious).
15) mount actuator, downpipe, water, plumbing, etc....
Edited by Tom Fenton on 23rd May, 2006.
Nick
Member #: 154
Midlands
any chance someone could make the piccies link work again please? or mail em to me and i'll host em.
please make that 2 months and not 3! my distibution has been improved!
JT
Member #: 637
Hertfordshire
yes i can say jimster has improved his distibution!!
could the pics be posted up again please or have they gone for ever?
cheers
josh
My build thread..
TurboDave16V
Pics seem to be gone forever. A little annoying, as all the other pics - including the BMC diesel A-series tractor have gone aswell :(
JT
Member #: 637
Hertfordshire
bugger
im sure it will all seem obviouse when i come to mod the manifold following the instructions!?
cheers
josh
My build thread..
I have some pics of the one i did ? Shall i post them ?
Phil.
TurboDave16V
Yes. You shall.
And you will.
Credit must go to our very own Turbodave who i believe was the person who initially came up with this idea. *wink*
Pic 1.
The studs were cut as close to the manifold face as possible using a hacksaw, then the manifold face was ground flat, as were both sides of the plate, this is to ensure a good seal as no gaskets were used. The hole in the plate is tapered from the larger T3 manifold opening down to the smaller size of the T2 exhaust housing. I filed the hole out by hand and managed to achieve a good radius and exact match to the Turbo housing by bolting it to an old housing and then doing the final filing.
The manifold was then redrilled and tapped, and new studs installed.
Pic 2.
As you can see the stud holes and exhaust hole are offest in the plate, this is to angle the the Turbo slightly to allow for better exhaust clearance.
Pic 3.
I tig welded the plate to the manifold rather than just sandwich it between, this obviously makes one less place for it to blow from ! lol.
Pic 4.
I had to grind a bit off one edge as you can see. This was to allow clearance for the intercooler hose coming off the compressor housing. This was probably only an issue as i'm using large diameter hoses.
Edited by Turbo Phil on 24th Oct, 2006.
Well I can do it. The rest of you are obviously frickin' retards......
those webs look funny, don't they normay go allthe way to the face?
i can see daves original pics : http://www.netsnapshot.com/pcw/b?KEY=2&ACCOUNT=4541
phil-send me some pics of helen and ill have a practise for you and show you how
Edited by Nic on 24th Oct, 2006.
Read point 12 of top post......
TurboDave16V
Nic, If you can see the pics it's because they're saved in your computer. Can you save each picture to a known location in 'my documents' then zip up and email them to me pls....
really???, ill do that now
TurboDave16V
hey - hang fire on that... It looks like netsnapshot is up and running agin!!!
Hooooooooraaaaaaayyyyyy!!!!
I'm going to save everything to the TM server...
ah bum, its on its way to the eaton address anyway
was it netsnapshot down? i never even noticed!!
racemini
Member #: 1359
Belgium
hello
racemini
Member #: 1359
Belgium
hello ,
i have put a metro turbo engine in my mini but i dont have the ecu and the solenoide ,how does i connect the wastegate-actuator? can someone help me ? thanks
The actuator can be connected to the 2 way brass fitting on the compressor housing. The other side of the fitting can be blocked.
Phil.
racemini
Member #: 1359
Belgium
thanks ,i've seen your site and i think i will solve it .
i didn't know where to connect the tube that went to the solenoide
thanks a lot
