Page: |
Home > MS Code Discussions > Idle control | |||||||
15th May, 2006 at 01:28:14am
I wanted to know what everyone who's planning on using Megasquirt for port injection were planning to use for idle control. Nothing, idle solenoid, or stepper motor?
88 Posts Member #: 720 Advanced Member Gloucestershire |
15th May, 2006 at 04:05:38pm
My personal opinion is that when starting a cold engine the use of ign timing only for idle control is not sufficient.
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
15th May, 2006 at 04:08:25pm
On 15/05/2006 09:50:12 mini1071s said:
I would say the wasted spark ignition is so important we don't use the stepper motor. So I would say solenoid or nothing. If we don't use a solenoid, how would we keep idle control? The ignition map? Never been too sure on this one! Control of nitrous or fuel pumps would be more important to me. What does anyone else think? there is a work in progress on the msefi forum for converting the pwm solenoid output to servo for idle controll. would allow you to then have all the spark outputs and sill have servo idle. but seing as you lot will be makign your own manifolds etc your probably aswell jsut useing a known-to-work pwm idle valve. turbo 16v k-series 11.9@118.9 :)
15th May, 2006 at 04:33:37pm
What is currently in the MS2 code is only fast idle control for warmup and static open loop idle. Some people are working on close loop control but it's not there yet.
11046 Posts Member #: 965 Post Whore Preston On The Brook |
20th Sep, 2006 at 02:19:44pm
MPIi uses a unipolar six wire motor in a bypass valve package on a five pin plug, as an idle 'air' controller
263 Posts Member #: 115 Senior Member Austria, near Vienna |
1st Jun, 2008 at 10:09:43pm
I am using the stepper motor in my 16V Bimmer conv. - it works good although it isn't closed loop - which is a shame...
Bimmer Twinky headed and turboed A-Series:
2nd Jun, 2008 at 08:51:57am
The latest MS2/Extra code can do closed loop idle control with a stepper.
17th Jun, 2008 at 08:50:46pm
Paul,
17th Jun, 2008 at 09:29:06pm
On 17th Jun, 2008 TurboHarry said:
Paul, have you ever seen a software that allows a stepper + PWM on the FIDLE port to be used parallel? No I have not. Are you sure you need PWM to control your water pump? Any DC pump is best speed controlled by variable voltage. I would look at a simple circuit that will run your pump at 12v at high temperature, but drop the voltage at lower temps. Maybe use a separate water temp sensor and some sort of amplifier circuit to handle the high currents. Electronics is not my field, so maybe someone else may care to comment on the practicalities. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
4559 Posts Member #: 786 Post Whore Bermingum |
17th Jun, 2008 at 09:42:59pm
152 Posts Member #: 1074 Advanced Member Northamptonshire |
17th Jun, 2008 at 11:04:57pm
I am using a 2 wire VDO idle control valve with MSV3 and it works really well
Edited by matnrach on 17th Jun, 2008. |
3588 Posts Member #: 655 Post Whore Northern Ireland |
17th Jun, 2008 at 11:37:13pm
Lots of factory ecu's use it, and some aftermarket allow closed loop idle control using ignition timing. My DTA S80 does this now
18th Jun, 2008 at 12:06:58am
20 Posts Member #: 2642 Member |
28th Jul, 2008 at 07:58:36am
Heres a copy of the MegaSquirt Feature comparison table.
Page: |
