Page: |
Home > FAQ / Knowledge > MG N/A cam, kent 266 & swift tune SW5 timing figures! | |||||||
12th Mar, 2006 at 09:37:01pm
there have been a lot of threads on cams & more in particular the MG/ N/A cam well heres some timing figures for you to make you own mind up! gents
Edited by BENROSS on 14th Mar, 2006.
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
31st May, 2006 at 11:24:13am
I like the design of the MG Cam with the extra exhaust duration, that is in my opinion what makes the A series work right, particularly on FI engines. You have a lot of gas so get the thing open quick, open high when you need it. Considering the port shapes and configuration, I'm surprised the SW5 is any good at all. It would be interesting to see whether it has a poly-harmonic profile. That might work. From what Mr Vizard said about forced induction, blowers prefer tighter LCA's which the SW-5 doesn't have. My present mini has a piper 270 which is 276-276 and not that much lift. I think the Kent 276 is shorter on the inlet, longer on the ex and has more lift on the exhaust, which is why it works better. In my opinion, the Avonbar Ph 2 cam is the ticket. but for a supercharger engine. Bugger off, I'm getting there. |
450 Posts Member #: 449 Senior Member Oxford |
31st May, 2006 at 05:51:27pm
I have the kent 266 in my lastest build and was originally in my metro turbo before I rebuilt ready for the mini, as soon as it came on boost it was an animal serious torque!!! |
31st May, 2006 at 10:40:54pm
yes my moneys on the kent 266 if you study the timing figures its just .... the bizz for a road going turbo motor
1st Jun, 2006 at 12:59:35pm
Ah good I have a kent 266, NA Metro and a SW5 in the shed somewhere. Whats the chances of that?! On 7th Nov, 2008 Nic said:
4th Dec, 2006 at 11:37:09pm
Timing figures for MEDT3 cam sort of phase 2 and a halfish
31st Jan, 2009 at 12:30:22pm
One in a million shot but does anyone know the cam timing figures for an SW10?
Edited by Rob H on 31st Jan, 2009. Isambard Kingdom Brunel said:
31st Jan, 2009 at 02:14:47pm
well i will post it here rob .................
27th Feb, 2010 at 09:23:11pm
Does anyone use the 266 CAM on a 998? I run a supercharger and I don't care the TB is on the wrong side.
27th Feb, 2010 at 10:32:16pm
Not as far as I know. But my current build will have one in (purely because I found one in my garage). Fastest 998 mini in the world? 13.05 1/4 mile 106mph
520 Posts Member #: 2093 Post Whore Grenoble, France |
3rd Mar, 2010 at 02:16:51pm
I'm in process of doing my stage2 with md266 on a 998.
Edited by alpa on 3rd Mar, 2010. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
3rd Mar, 2010 at 06:57:10pm
ordered by 266 for my 998. I don't think it will be as good as the Vmax 265 but it should be much better than my std cam. I run a supercharger and I don't care the TB is on the wrong side.
38 Posts Member #: 4584 Member Perth, Australia |
21st Feb, 2011 at 09:12:13am
Does anyone have the timing figures for the Vmax 265 cam? I contacted Stuart Gurr a few weeks ago and he says he is no longer selling cams. Would be nice to know what cam profile he arrived at for supercharger use. |
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
21st Feb, 2011 at 10:32:27am
I dont pretend to know anything about cam design at all, but I am putting an MG Metro N/A cam in the present rebuild.I cant work out from the figures quoted how I should time it. I seem to remember that I should set it to maximum lift on the inlet valve at 108 degrees ATDC - any comments please ? |
21st Feb, 2011 at 11:00:57am
We have the van's MG cam at 108, seemed to work well.
i tried putting soap on it , and heating it to brown , then slathered my new lube on it ![]() |
21st Feb, 2011 at 11:03:49am
Then thats what I shall set it to - thanks Andy |
21st Feb, 2011 at 09:07:46pm
Andy, have you tried the vmax cam? |
22nd Feb, 2011 at 07:14:26am
Mines the 274, but I'm a long way from engine building at the moment unfortunately. On 11th Feb, 2015 robert said:
22nd Feb, 2011 at 07:46:24pm
Me too, but its fun planning and collecting all the pieces! |
22nd Feb, 2011 at 08:26:16pm
Page: |
