Page: |
Home > Help Needed / General Tech Chat > Fuel injection.. emeralds example | |||||||
8th Mar, 2004 at 05:20:25pm
as sene here http://www.emeraldm3d.com/em_projects_Aseries.html turbo 16v k-series 11.9@118.9 :)
Site Admin ![]() 9404 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
8th Mar, 2004 at 10:44:07pm
I run emeralds ECU on my mini turbo, I spoke to them about this, they don't you will get enough fuel from it to work on a turbo mini, but they are willing to give it a try with no promises Team www.sheepspeed.com Racing
8th Mar, 2004 at 10:52:26pm
wel i dont se why bigger injectors cant be used, its not liek direct port injection where the pulses bust be very very precisely controlled, i meen the injector is a good bit up the inlet tract.
9th Mar, 2004 at 08:07:08am
Emerald did tey injecting turbo a series before, but it made bad power. TurboDave is the boy to speak to on this. Team www.sheepspeed.com Racing
9th Mar, 2004 at 02:35:15pm
I am planning on putting a mega squirt&spark on my turbo. I have most of the kit together at the moment. The ignition side should be fitted to my non turbo soon and then transfered to the turbo when i have the hang of it. Then a full ignition and injection will be fitted to a hilman imp engine for testing. They are 8 port heads so it will be easier. After this is working the turbo will be injected.
http://www.twin-turbo.co.uk
9th Mar, 2004 at 03:05:12pm
Bigger injectors? How big, and how to accurately control at tickover?
9th Mar, 2004 at 03:45:40pm
reason for the hif body was a simple one, iv got plenty siting around and they bolt straight on.
Edited by evolotion on 9th Mar, 2004. turbo 16v k-series 11.9@118.9 :)
9th Mar, 2004 at 05:36:31pm
What you need to consider is not the length of the inlet tract, but the fact that you are injecting fuel at a point that might not be the optimum for the engine at the particular instance. I believe this is further complicated with a forced induction engine as the port effectivly increases efficiency wrt manifold pressure, so might need two maps - one correcting the injection event for rpm, the other then correcting the rpm event for manifold pressure...
9th Mar, 2004 at 05:49:30pm
well, injecting a high powered A serie, ouarf!!, good luck,
9th Mar, 2004 at 07:31:13pm
argh, no fab ur missing the point i was trying to make.. i dont want to go down the route of direct port injection as i know the issues that surround this, basically i wanted to make an electric carb (for want of a beter description!)
9th Mar, 2004 at 08:10:04pm
Soory; i had read this thread slightly too fast :),
10th Mar, 2004 at 01:28:41pm
if you stick mapped ignition on there, your part throttle (cruise) economy, power, drivability, and acceleration will ALL imporve greatly - so long as it's set up right!!!
10th Mar, 2004 at 01:56:39pm
I totally agree. Putting mapped ignition on gives the best benifit although unlikely to increase top end power it will certainly give a much flatter torque curve, off boost power and throttle response will also be much improved. Myself I am not bothered about economy as the turbo is a race car that only does 3mpg anyway. But it will increase mpg.
10th Mar, 2004 at 05:13:53pm
More food for thought turbo 16v k-series 11.9@118.9 :)
![]() 164 Posts Member #: 206 Advanced Member Milton Keynes |
11th Mar, 2004 at 04:34:05pm
I would have a go with two injectors, one small primary and a larger secondary, this would help in getting enough fuel in at high rpm, but still have good atomisation at low rpm, as ISTR you can control the injectors independently. I'll be using the emerald system on my justy/ and rx 7 turbo engines Edited by PaulM on 11th Mar, 2004. 9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked |
12th Mar, 2004 at 07:08:31am
As dave said , I would also prefering to go with an hif44 and lightening my pockets to buy a programable ignition, I like a lot Jim's emerald system, and I have bought one for a friend (but didn't have the time yet to install it yet); the contact with Dave Walker at Emerald was very good and the system was rapidly delivered here in France. I will also use one for my new turbo mini
![]() 4629 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
13th Mar, 2004 at 07:44:01pm
Check this out http://www.onlineshowoff.com/index.asp?sec...rname=miniturbo
13th Mar, 2004 at 08:30:10pm
http://www.minipark.net/html/car-3429.html
13th Mar, 2004 at 08:32:55pm
http://www.minipark.net/car_image.html?thi...%5CBild+080.jpg
Page: |
