Page: |
Home > A-Series EFI / Injection > Microsquirt | |||||||
47 Posts Member #: 830 Member SLC, UT |
17th Jan, 2006 at 10:42:45pm
Has anyone else seen this?
-Tyler
1300 Posts Member #: 829 Post Whore essex |
17th Jan, 2006 at 10:51:49pm
not bad for the money 1293 Turbo mini
17th Jan, 2006 at 11:24:13pm
It is interesting indeed. They need to correct the fact that it cannot be distributorless but other than that it's nice. And anything developped for the standard MS-II wiil be compatible.
18th Jan, 2006 at 01:12:13am
Yeah, but that gives me time to save
-Tyler
18th Jan, 2006 at 01:27:43am
The current version of MS-II and the upcoming versions only have a single ignition output. The distributorless version (up to 6 ignition outputs) is the MSnS-extra which is only available for MS-I which is the HC908 processor with assembler code. The MS-II and the microsquirt have the HCS12 processor and C code. |
18th Jan, 2006 at 01:32:28am
All of the Ford EDIS, GM HEI, and stuff still works in MSII, as far as I have seen and they are all distributorless. -Tyler
18th Jan, 2006 at 02:35:14am
You're right. I was thinking of direct ignition control without an external ignition module and forgot about those. I know that Ford EDIS and TFI work but I'm not sure about GM or others. |
3329 Posts Member #: 184 Senior Member Melton Mowbray, Pie Country |
18th Jan, 2006 at 09:46:15am
That is quite interesting, but I would like to see the price. Based on the price of the surface mount price of the MSII I think it will be expensive. I guess for a motorbike or lawn mower it will be very useful. I water proof my MS by putting it inside the car. Even in a leaky mini it stays perfectly dry. http://www.twin-turbo.co.uk
18th Jan, 2006 at 04:13:34pm
Last time it rained, I had 3" of water in the mini...
-Tyler
19th Jan, 2006 at 06:14:46pm
On 18/01/2006 16:13:34 mrbell said:
Last time it rained, I had 3" of water in the mini... ...AND I live in the deserts of Utah. I suppose I should get that gaping hole fixed, eh? shut the sunroof? Crystal Sound Audio said:
19th Jan, 2006 at 11:34:49pm
heh... if only...
-Tyler
19th Jan, 2006 at 11:43:37pm
drill a big hole in the floor job done 1293 Turbo mini
20th Jan, 2006 at 01:08:09am
There are three holes already, but I was parked so that the water all went to the back and the holes are up front.
-Tyler
20th Jan, 2006 at 08:39:53am
They are not yet released....
AlexF |
Page: |
