| Home > MS Code Discussions > Feature wish list | |||||||
6th Jan, 2006 at 05:27:30am
There is now an initial code version that supports injection timing (with respect to the start of the injection pulse) with a 3-D table, injector staging with either 2 tables or with a single table and a ratio for any injector mix of size and impedance, and mid-pulse timing with a single advance value (with one advance value for unstaged and another for staged injection). This code version has sacrificed ignition capability (for ease of implementation) and, potentially, does not provide very good accuracy of injection timing during certain situations such as engine startup and very rapid acceleration.
7th Jan, 2006 at 08:56:42pm
When you say fuel 'cut off' do you mean it just won't accept any increase over the stated injector duration - no matter what is in the fuel table?
Edited by turbodave16v on 7th Jan, 2006. On 17th Nov, 2014 Tom Fenton said:
7th Jan, 2006 at 09:52:48pm
Having a LED activated when the pulsewidth reaches a certain limit would be quite easy to implement in the code and there are auxiliary outputs on the MSII. It would be more difficult and computation intensive to have that as percent of duty cycle but still not too bad.
7th Jan, 2006 at 09:59:16pm
Another point I should add is that some of the computation limits could be done in Megatune and presented in the real-time display. However, that means that a manual operation would be needed for protecting the engine.
47 Posts Member #: 830 Member SLC, UT |
30th Jan, 2006 at 04:40:11pm
Since you asked me to put this in here for you...
-Tyler
13th Feb, 2006 at 03:29:07pm
I was flicking through some old mags over the weekend and came across an article by dave walker where he was using diferent timing for the inner and outer cylinders on a CVH, aparently it worked to an extent, with the mini head I get the impression that this give a better result than the CVH. On 28th Aug, 2011 Kean said:
18th Aug, 2006 at 06:54:38pm
The reason they don't work is the feedback I believe - or maybe the sampling rate of the unit?
