Page: |
Home > MS Code Discussions > Staged injectors with MS ? | |||||||
3rd Jan, 2006 at 07:41:29pm
3rd Jan, 2006 at 07:49:20pm
yes it does AlexF |
3rd Jan, 2006 at 08:08:56pm
The MSII does not but it has the possibility of using 2 maps, one per injector driver. This is more trouble for tuning but it allows more flexibility since you can have different size injectors and decide how they are staged as a function of rpm and load.
3rd Jan, 2006 at 08:12:38pm
Another point: if you want to have an idea of what is available in MSII you can download Megatune and run it even without having the ECU. Just go through the menus and you'll see the options and what it would be like to tune with it. You can use the standard MSII ini file or use the one I posted on the MS forum.
4th Jan, 2006 at 08:15:33am
Why not use V3 then?
AlexF |
47 Posts Member #: 830 Member SLC, UT |
4th Jan, 2006 at 04:52:45pm
V3 instead of?
-Tyler
4th Jan, 2006 at 09:14:19pm
I have added staged injection to my initial code. This is similar to the MSnS-extra code staging except that it's only triggered by RPM but you still can get 2 injectors of different size. The staging is activated when the highest RPM point is reached and disabled when the RPMs come down to the lowest RPM point. In addition to that, the second bank of injectors is no longer used for cranking and prime pulse when in dual table or staged injection modes. That way if you have 2 injectors per port, only the primary one is used when starting the engine.
4th Jan, 2006 at 09:43:18pm
On 04/01/2006 21:14:19 jbelanger said:
This is similar to the MSnS-extra code Thats what I was thinking of... not v3 at all doh! ![]() AlexF |
63 Posts Member #: 834 Advanced Member Falmouth, Cornwall |
12th Jan, 2006 at 04:09:15pm
That then as I understand it must be the most advanced ECU out there! This is amazing stuff. I'm downloading the code into Megatune now to have a play. Then I have to decide on the best hardware approach, going on the turbo 850 which will make 160 bhp tops, (998 bore, 850 crank, 936cc). Peter
12th Jan, 2006 at 04:50:29pm
nah any std ford ECU outstrips it... even rover mems does!
AlexF |
12th Jan, 2006 at 04:53:34pm
I just meant aftermarket ones really, though sounds a bit more complex than you have stated TBH. Maybe I am just thick :) Peter
12th Jan, 2006 at 06:08:41pm
There are even extremely complex aftermarket ECU's. They just happen to be very expensive. They also tend to include alot of features that I personally will never use.
-Tyler
12th Jan, 2006 at 07:33:57pm
Yeah pectel T10 is expensive LOL
AlexF |
Page: |
