Home > A-Series EFI / Injection > direct injection
stuart gurr - vmaxscart
Member #: 350
Turboing minis since '89
Supercharging minis since '04
anyone given direct injection some thought ?
bosch sell parts for factory installations , or take the necessary off an existing engine eg, mitsubishi GDI ?
i think the injector could be possitioned in the head next to the plug (enough metal around that area in the casting for both )
no charge robbing , injectors that increase swirl and can localise burn around the plug , perfect mixture at all times?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Do you want to run homogenious or stratified?
(sp)
Alex
AlexF
TurboDave16V
I've no idea on the spelling!
I've thought about it - Marcel has thought about it more though....
As soon as i heard (and i could be mistaken) 1800psi rail pressures I went off the idea... quickly... LOL!
I have never thought about this, however from what I have read regarding the performance of the Mitsubishi GDi engines I understand there is still some work to be done to get this to work properly.
A friend with a Shogun Pinin fitted with a 2.0 GDi engine has just had to take it back to the dealership for the second time, for what they described as a "de-coke".
Surely a modern engine running correctly on modern fuels would not require this if all was well.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
The inlet valve coke badly as there is no fuel to clean them!!
You dont need 1800 psi, thats for diesels!
80-100 bar will do it *happy*
Alex
AlexF
curta_crankn_daddy
Member #: 799
Canada, eh?
On 30/12/2005 22:28:42 AlexF2003 said:
You dont need 1800 psi, thats for diesels! 80-100 bar will do it *happy*
Alex
well isn't 80-100 bar 1200-1500 PSI? I was reading about direct injection in Automotive Engineering so I just looked back to check my reference. Without doing too much research, here's an article from January '03 about the BMW V12 using rail pressures of 30-100 bar. That's 10-30 times what fuel rails run at for EFI setups.
The idea behind direct injection is to put the fuel charge diretly into the cylinder under extremely high pressure. This will 1) substantially reduce the injection event timing 2) instantly vaporize the fuel (as opposed to atomize it) and thereby take advantage of the latent heat of vaporization in the cylinder which will in turn allow for increased compression ratio (the BMW V12 is spec'ed at 11.3:1) and/or allow increased igntion advance and 3) ensure complete burn of the fuel charge, thereby harnessing all the available energy and reduce emissions.
IF you could source a pump that will make 100 bar and IF you could get injectors and IF you could convince an ECU to control the thing (I haven't researched any of this) then it should be quite possible to adapt an A series block. There's plenty of meat in the block deck or cylinder head face to drill a small hole, or indeed even mill a trough in the block deck and cover with a gasket. I was reading about the Delphi piezo injector designed to handle pressures in this range, but I was looking at it for its sub-millisecond response time.
Now if I didn't have to spend 7.25 hours every damn day sitting in a 10x10 fabric wall box I'd be more than happy to explore this. Donations to my Paypal account are more than welcome *wink*
www.starchak.ca and www.TDCperformance.ca
evolotion
Member #: 83
Glasgow, Scotland
someone care to explain (assuming you cant) why you couldnt technically run craploads of boost on a high CR engine? if you retarded teh injection event to a point where it was after the point of detonation, if that makes sence.
Denis O'Brien.
TurboDave16V
In simple terms evo - you've retarded the ignmition so far the engine will never make any decent power ... It'll make boost, which is great for 'chav wars' but you'll be racing milkfloats to the finish line!
Member #: 350
so the inlet valve may be cokeing because the inlet durations long? or when the injector is trying to get the mixture localised to the plug and its too close to the inl. valve ?
could be shortened with forced induction ?
i know the fuel pressure makes the thing like a time bomb , but hoses, pumps and fittings etc are in general production now
evolotion
Member #: 83
Glasgow, Scotland
doubt it would be that dangerous. i meen the part of the fuel system that is at that pressure will only be a very short run, 1 leak and due to the hydraulic nature of the working fluid by the time a teensy weensy amount has excaped the fuel rail will be down to a more civil pressure. imho ofcource.. i would if there was a noteable gain to be had.
Denis O'Brien.
Hmm I don't know, 1500psi is a HELL of a lot! I work on hydraulic systems that run at up to 800psi, trust me that doing anything at that sort of pressure is hairy enough, I would not want to be messing with 1500psi. Yesterday I had to reintroduce a pressure vessel as big as a regular house at about 810psi to a valve skid that had been drained for repair. Not pleasant, in fact I will admit I was bloody windy about doing it!
As far as fuel pressures go, the common rail diesels are running 1800 bar on full boost. Yes BAR! *surprised* The problem the Mitsi's have is with the injectors clogging. As you will probably know from leaving an injection car standing around is the injectors get clogged with dried fuel, when you put the injector in the combustion chamber this happens a lot quicker. The ecu will look at the o2 sensor and keep adjusting the pulse width until it can't go any further, then its dealer time....
Gavin. :)
Doodmeister
Member #: 149
Alberta, Canada
Are you MAD 26000 PSI. ??
Shit i had to edit this as i've just read Volvo are looking at using 2000 Bar fuel rail pressures. Holy Cow Batman thats high.
Edited by Doodmeister on 4th Jan, 2006.
@ Doodmeister.... It does sound crazy, 'till you realise they're already doing it. And I'm already behind the times!!!!!!!!!!!! *surprised*
Gavin. :)
I'm guessing that the fuel pressure is dependant on what point in the cycle the injection takes place, ie if you inject during the induction stroke you're going to need considerable less fuel pressure that if you inject at the top of the compression stroke, or have I got the wrong end of the stick again?
TurboDave16V
No idea. I need to re-read the above on my 486 to understand it...
Advantage
Member #: 1450
Near Paris - France
Even if you didn't need to pressurise the fuel much at the induction stroke, you still need an injector nose that can stand the rigours of the explosion ...
I like to think about crazy projects but this one I have given up because it won't give back the effort it needs.
(you still get interrobing issues with a big cam I guess)
But hey, why not !
I believe converting your 5 porter in a 7 porter with home tools would be less demanding and more rewarding ...
Rusty by nature
johnK
Member #: 690
Norfolk
Well as SC are the only company in the UK, possibly Europe or further afield to be able to run,map and tune common rail diesel engines (we know we are as we have the contracts in place where others have failed) when they aren't in cars (you can't simply use the oe ecu as that requires you have the following parts as well, abs,dashboard,steering systems,chassis looms, alarms,immobilisers etc)means we could also run direct injection petrol engines as the injector technology is similar.
full control over the vnt turbos and 3 or more seperate injection cycles to control noise/power/emmisions - imagine that in a mini engine.lol!
JK
If Carling made Mini engines
JK
is that a 2011 preview? *happy*
evolotion
Member #: 83
Glasgow, Scotland
ooh old thread! since then i have done work on mitsubishi gdi engines, particualrly preplacing the high pressure pumps that f*ck up. on the bright side if the high pressure line is ruptured, you only get a wee bit of petrol out, not an exposion, on the downside there shite, and very expensive. also read that the emissions are very nasty due to the nature of the burn.. as in nasty to us mortals, could be a load of crap but raised my eyebrow!
Denis O'Brien.
