Page: |
Home > A-Series EFI / Injection > Aftermarket injection | |||||||
7765 Posts Member #: 74 I pick holes in everything.. Chief ancient post excavator |
16th Nov, 2005 at 02:22:40pm
So, anyone running this? On 13th Jul, 2012 Ben H said:
30 Posts Member #: 798 I invented dizzy blanking plugs Midlands |
2nd Dec, 2005 at 11:01:40pm
I was running EFI in 1997 along with Coil per plug and fully mappable ECU 100% better than Carb and dizzy.
Thanks
2nd Dec, 2005 at 11:15:12pm
was it the minijection system from A1 in leigh perchance? On 17th Nov, 2014 Tom Fenton said:
3rd Dec, 2005 at 09:09:10am
No Dave......... Keep guessing ........... oh alright then it was and still is a DTA unit excellent bit of kit and its ready for when I do my 16V 1380 Turbo etc.......
Thanks
3rd Dec, 2005 at 03:37:38pm
Coil -per - plug?
3rd Dec, 2005 at 06:50:27pm
Yes I have some early pictures - unfortunately the car was used to try and right off a 44 Tonne milk tanker (full of milk) - I could still open both the doors and the police where looking for a corpse or two - still here but changed to Central - used to be in Back S*****
Thanks
4th Dec, 2005 at 10:43:27am
email them to alex@afracing.com and I'll host them for you...
AlexF |
6th Dec, 2005 at 09:32:03am
On 03/12/2005 15:37:38 TurboDave said:
IMO DTAe48 is not an 'excellent bit of kit' when it comes to the A-series... It is a good ecu generally, but as well suited to the A-series as coffee is to custard. Have you ever tried coffee and custard then Dave ???? Thanks
6th Dec, 2005 at 02:21:47pm
I don't need to.
6th Dec, 2005 at 09:34:32pm
Works better with coil per plug and variable timing (firing) angle, and wider spark durations between 6 and 9ms suits the A series better than most !! did you get a dodgy one or maybe someone didn't make up the harness properely
Thanks
6th Dec, 2005 at 09:54:20pm
Topic is called aftermarket injection. Thought that's what we were discussing.
7th Dec, 2005 at 09:25:03am
On 06/12/2005 21:54:20 TurboDave said:
Coil per plug, whatever. It's exactly the same as wasted spark. In fact - it's not. The coils on wasted sparks are at least double to power of motorcycle coil-per-plug units (as on yours) so a coil pack off any modern motor would inherrently give a superior spark... Launch control on Older DTA systems is a piece of turd IMO. The control on the later versions far improved it. Even so - single wheel launch control - hmmmm. The day DTA can out-perform my clutch and accelerator foor on a Rainy saturday in manchester, then a sunny sunday in SantaPod without dicking about trying differnt settings is the day i'll show my arse in Burtons Window... Dave you are making TOO many assumptions - Firstly what makes you so sure that I am using motorcyle coils !!! They are not from a motorcycle - simple fact !!! They were experimental coils with a minimum of 85,000v of spark - whereas your "boggo" units will be hard pressed to maintain 65kv with any reliability !!! Further - single wheel TC is simple, and a simplistic design is often the best, easiest and less prone to failure - it works, it has also been working on far more cars around the world than you could imagine !! Burtons doesn't need your arse to sell their wares, but if thats what you want to do, I am sure we can find one that would accomodate your wishes !!! It's unfortunate that some people seem to feel the need to slag everything off just because they couldn't get it to work for themselves !!! Thanks
4436 Posts Member #: 164 The Stig.. Newport Pagnell |
7th Dec, 2005 at 11:06:21am
Dave is the last person to "slag" anyone off.
7th Dec, 2005 at 01:29:17pm
I'll see if i can find my picture of EXACTLY the same units from the A1 services 'minijection' efi system from 1999 that had exactly the same coils then - AND were motorbike spec units...
368 Posts Member #: 362 Senior Member durham area |
7th Dec, 2005 at 05:02:56pm
best get the hand bags out LOL love that straight cut scream!!!
Page: |
