Page: |
Home > Help Needed / General Tech Chat > | |||||||
79 Posts Member #: 12240 Advanced Member Kent |
28th Oct, 2024 at 04:36:24pm
On 23rd Oct, 2024 stevieturbo said:
Make sure the tank is low enough relative to the nozzle that water doesn't naturally drain out the nozzle If tank is rear mounted, mount pump close to the tank. And surely you can get a long spout to fill ? If using methanol, you could go, through a fair bit. Much less so water. Depends on usage of course. If using it aggressively, tuning to optimise power etc...bare in mind if it fails you can ( will ) kill your engine. If fittings fail etc....same applies. The tank is probably about the same height as the nozzle.i probably could fill it up using a long spout or I could drill a 10mm hole in the parcel shelf and use a funnel. The pump is in the boot under the tank little bit forward by the rear lights |
Page: |
