Clearing all my a series parts.
Photos of everything available.
Collection near Dorking, or can post.
All prices are ono.
Alloy rocker cover.
Has had the fins removed off the top and 3 breathers added. In excellent condition.
Looks very different and is nice and light!
£100
Billet 7 port turbo head package
Selling my Specialist Components head as a package with almost everything needed to bolt onto any A series and turn it into a monster.
The head has just come back from TCK in a better than new spec. It’s had all new seats, guides, valves and valve springs and is built ready to bolt on. TCK also put helicoils in the rocker post stud holes and made some steel spreader shims to go under the rocker posts. The head is dry decked with brass plugs and the end plate has been adapted for a dry deck fitting. 24.4cc chambers.
The Turbo is a Garret GT1752. It’s been trimmed a bit. Comes with oil feed/return and water feed/return.
Exhaust manifold was made by fusion fabrications to suit this head. It top mounts the turbo and is a lovely bit of kit. Makes it super easy to work on.
The Inlet manifold is custom made by TCK.
A complete specialist components SCS delta engine management is included. The loom will need sorting out as it will need to be split to be removed but it’s all there. AT power throttle body, Bosch injections, fuel rail, IAT sensor etc.
New prices were as follows:
Specialist Components billet 7 port head £2820
GT1752 turbo £250
Fusion exhaust manifold/downpipe £600
TCK inlet manifold £600
SCS delta fuel Injection £2500
I would like £4995 for it all.
Located near Dorking, Surrey
Cometic gasket and arp studs in the photo are not included.
Metro thermostat take off. Painted in VHT wrinkle paint. With Ti bolts and new gasket,
£30
5L of millers CTV unopened
£40
Verto slave kit, lightened slave, Ti rod, lightened centre bolt, titanium over centre adjustment nuts and minisport HD arm.
£90
Gt1752 turbo, all trimmed back and the compressor side is polished.
£150
Fusion top mount t3 fit turbo exhaust manifold and downpipe. Suit a gt17. Ideal for 7 port heads.
£500
Avonbar phase 2 cam with followers good used condition.
£150
Low profile remote oil filter take off with AN fitting
£20.
Metro turbo block STD, will need at least a hone.
£395
Mk2 fibreglass bootlid
£60
Edited by jonny f on 28th Jan, 2025.
