Home > Help Needed / General Tech Chat > Methanol injection
jamesRs250
Member #: 12240
Kent
Has anyone fitted methanol injection?
I need some ideas how to fit the tank in the boot it's a AEM 1.15 Gallon tank.
Thanks
I have pictures of how I did mine, but I don’t know how to post them on here anymore.
Phil.
jamesRs250
Member #: 12240
Kent
OK cool...I don't know how to post pictures on here either. The pump as everything else is done.
Phil.
jamesRs250
Member #: 12240
Kent
I have actually fitted it now to the rear seat panel using 4 studs and wing nuts. Hopefully it should not be too much of a problem to take off and fill because I don't think it's somethink what's going to be filled up every week. I can still get the cap off so I could also fill the tank up with a large syringe for filling up gearbox oil or I could cut a hole above the parcel shelf.
I would add a photo if I knew how to.
Edited by jamesRs250 on 28th Oct, 2024.
Make sure the tank is low enough relative to the nozzle that water doesn't naturally drain out the nozzle
If tank is rear mounted, mount pump close to the tank.
And surely you can get a long spout to fill ?
If using methanol, you could go, through a fair bit. Much less so water.
Depends on usage of course.
If using it aggressively, tuning to optimise power etc...bare in mind if it fails you can ( will ) kill your engine.
If fittings fail etc....same applies.
jamesRs250
Member #: 12240
Kent
The tank is probably about the same height as the nozzle.i probably could fill it up using a long spout or I could drill a 10mm hole in the parcel shelf and use a funnel. The pump is in the boot under the tank little bit forward by the rear lights
