Home > Help Needed / General Tech Chat >
jamesRs250
Member #: 12240
Kent
It will be fine for a 1380 obviously you will need to get the compression down a bit.
The newer vmax kit is better. You can get a carb heater to help with carb icing.
There are a couple of posts on here using that supercharger. Have a search on the search bar I found it works better if you search using a PC / laptop
