Page: |
Home > Help Needed / General Tech Chat > fuel issue? | |||||||
2 Posts Member #: 12376 Junior Member |
10th Sep, 2024 at 05:58:30pm
hey everyone, ive recently bought a mini with a metro turbo engine in it. im trying to get it running right as it will start eventually but wont rev? i have checked the pressure regulator and im getting 3.5bar out of it, but it still wont rev. ive fitted a new fuel filter but it is only filling around a quarter full and wont go anymore...is this normal or should it be filling? im a total newbie when it comes to these turbo engines, i have plenty of experience with 998's but this is baffling me!
3590 Posts Member #: 655 Post Whore Northern Ireland |
10th Sep, 2024 at 08:51:30pm
On 10th Sep, 2024 Jeffvader83 said:
hey everyone, ive recently bought a mini with a metro turbo engine in it. im trying to get it running right as it will start eventually but wont rev? i have checked the pressure regulator and im getting 3.5bar out of it, but it still wont rev. ive fitted a new fuel filter but it is only filling around a quarter full and wont go anymore...is this normal or should it be filling? im a total newbie when it comes to these turbo engines, i have plenty of experience with 998's but this is baffling me! also what compression should i be getting when doing a compression test as i cant find a definitive answer! thanks in advance ![]() 3.5 bar would be rather worrying on a carburettor engine and would undoubtedly see fuel flying out of every orifice possible. I hope you meant 3.5psi. Whether turbo or n/a, makes zero difference to idle and basic running. So at idle, what are mixtures like ? does it start normally ? idle normally ? Was it bought with known problems or was it supposed to run ok ? 9.85 @ 145mph
10th Sep, 2024 at 10:39:11pm
Sorry, yes I mean psi 🤦🏻♂️ when I bought it the previous owner said it was hard to start. After having half an hour checking firing order, plugs etc I've managed to get it starting fairly easily.
256 Posts Member #: 11017 Senior Member Shropshire |
12th Sep, 2024 at 12:48:35pm
Does the throttle pot move ok? What fluid is in it? |
12th Sep, 2024 at 04:40:51pm
Sorry, yes I mean psi 🤦🏻♂️ when I bought it the previous owner said it was hard to start. After having half an hour checking firing order, plugs etc I've managed to get it starting fairly easily. It seems to me that it's getting starved of fuel when you rev it? So again, what are mixtures like at idle and during these events ? No need to guess. Get real data. 9.85 @ 145mph
81 Posts Member #: 12240 Advanced Member Kent |
13th Sep, 2024 at 09:41:52pm
Does carburetor the dash pot move freely?. Is the throttle butterfly working not snapped shaft? |
Page: |
