Page: |
Home > A-Series EFI / Injection > | |||||||
256 Posts Member #: 11017 Senior Member Shropshire |
26th Aug, 2024 at 07:24:29am
On 24th Aug, 2024 stevieturbo said:
I used a Subaru pedal for my car ( not Mini ), pedal feels fine in it. It's fairly easy to bolt to a flat bulkhead, and then just modify the pedal side a bit. And what do you mean it trips out Steve ? It kept throwing up errors due to the mismatch in voltages between APP 1 and 2. The new pedal seems to have sorted it now. In terms of the fuel pressure, I have a condition that if actual and predicted are out by 20kpa or more, it sets the boost solenoid duty to 0%, which is around 6 psi on actuator. |
Page: |
