Home > Help Needed / General Tech Chat > A+ third motion shaft (18mm) product specs
steveg3731
Member #: 10780
Adelaide
Hi all... just building an A+ gearbox for a turbo engine to be used in hill climbs.
Have seen reports of the third motion shaft snapping of at the final drive nut.
Is there one brand that you should stay away from ??
I'm converting a 14mm to 18mm to allow use of bigger bearings.
Edited by steveg3731 on 17th Jul, 2024.
