Page: |
Home > Help Needed / General Tech Chat > Conflicting readings between oil pressure gauge and oil warning light. | |||||||
4304 Posts Member #: 1321 Post Whore Wiltshire |
21st Mar, 2024 at 09:28:36pm
I seem to have a bit of a weird oil pressure issue with the twin cam.
2488 Posts Member #: 1954 Post Whore Luton Bedfordshire |
22nd Mar, 2024 at 12:56:54pm
I have had this same issue but not on a twin cam. and i find oil pressure switches to be a sensitive crowd they are not simple on off devices and their operation can hunt between values. When the whole situation is controlled by the ecu the ecu triggers the light, but then you have no idea as to the actual oil pressure do you. With a gauge fitted you can verify the function of the switch, I would not verify the function or reading of a gauge using a switch. The one thing I would say is that my oil pressure gauge sits at 50psi hot or cold at idle. So you may be within that hunting range of that particular switch, which means this may be indicative of another issue. Own the day
26th Mar, 2024 at 05:09:12pm
Thats informative.
27th Mar, 2024 at 02:31:45pm
Ask yourself what parasitic losses you have in your system. You have the turbo for one and the under crown oil jets. How good are the clearances on the crank journals and the cam shafts?
Edited by Mr Joshua on 27th Mar, 2024. Own the day
3588 Posts Member #: 655 Post Whore Northern Ireland |
28th Apr, 2024 at 08:14:54am
On 21st Mar, 2024 minimole23 said:
I seem to have a bit of a weird oil pressure issue with the twin cam. It only came to light when fitting a 20psi warning switch, for a bit of added safety margin. The oil pressure gauge is indicating 40psi at hot idle @70 degrees celcius. Yet the oil light is just being tickled. any revs and the pressure picks up and the light is not being tickled. I fitted a new stack oil pressure gauge to validate that is accurate. The take off for the head, switch and gauge are all taken from the main gallery/original switch location. I have removed it from the car and hooked up to the air line and oil pressure gauge and it does seem to be activating at 20 psi. Tried pouring a kettle of boiling water on it too to see if that made any difference to try to mimic when the oil is hot. I can therefore only assume there is an issue. Whether that be pulling air in from somewhere or the oil pressure relif valve getting sticky, though freed this off tonight and have yet to test. Any thoughts on the matter? I feel a precactionary engine out job may be in order. Are both items measuring from the same point in the system ? Have you verified your gauge is accurate ? 9.85 @ 145mph
29th Apr, 2024 at 09:55:34am
I changed to a MOCAL sender, which has not yet illuminated. That said I have not had the oil temps right up beyond 80 ish yet.
256 Posts Member #: 11017 Senior Member Shropshire |
29th Apr, 2024 at 10:44:13am
I ditched the oil pressure switch as the accuracy for such a cheaply mass manufacturerd item isn't worth it. I have an oil pressure sensor into the ECU and would rather trust that. |
Page: |
