Page: |
Home > Help Needed / General Tech Chat > Morris minor 1275 Turbo Breathers | |||||||
9 Posts Member #: 10388 Junior Member |
2nd Mar, 2024 at 04:35:42pm
Hi, I have a Morris minor with a 1275 Turbo engine fitted.
855 Posts Member #: 951 Post Whore Bromsgrove |
3rd Mar, 2024 at 10:09:33am
Sorry you will always have a leak. Good rear main bearing tolerance helps, but at any serious boost level it will leak a bit. I tried the various rear seal kits to no effect. I have roughly the sme breather setup as you, and run 23 psi of boost. 'Where does the engine go?' |
4304 Posts Member #: 1321 Post Whore Wiltshire |
4th Mar, 2024 at 06:26:46am
How large is the outlet on the breather box? Any photos of the set up On 7th Oct, 2010 5haneJ said:
117 Posts Member #: 2576 Advanced Member South Staffordshire |
4th Mar, 2024 at 07:37:34pm
I recall seeing somewhere that the tolerances on those seal kits can be a bit loose. I have been trying to recall where I saw it discussed. Think it might have been on a frog eye, rather than a moggy. There was a solution that didn't involve going back to a scroll HOSS |
14 Posts Member #: 12343 Member mid devon |
10th Mar, 2024 at 11:37:42am
On 3rd Mar, 2024 steve1275 said:
Sorry you will always have a leak. Good rear main bearing tolerance helps, but at any serious boost level it will leak a bit. I tried the various rear seal kits to no effect. I have roughly the sme breather setup as you, and run 23 psi of boost. 23 psi of boost ?? What build do you have mate ? |
11th Mar, 2024 at 08:31:46am
GT1752 on Matty manifold, Full race head, Forged pistons, Ph1 cam, 8:2 cr, 1.5 rockers. Street and strip. NOS on the strip. 'Where does the engine go?' |
2488 Posts Member #: 1954 Post Whore Luton Bedfordshire |
11th Mar, 2024 at 01:12:21pm
On 11th Mar, 2024 steve1275 said:
GT1752 on Matty manifold, Full race head, Forged pistons, Ph1 cam, 8:2 cr, 1.5 rockers. Street and strip. NOS on the strip. What's your power out of interest I can run with 28psi on the road when lessons need to be taught but i have never had it on a dyno. Own the day
11th Mar, 2024 at 05:06:56pm
About 230 bhp plus 70 bhp from the NOS 'Where does the engine go?' |
Page: |
