Home > Help Needed / General Tech Chat > SPI fuel pump for turbo
robsturbo
Member #: 12343
mid devon
Morning guys
Just a quick question, is a cooper spi fuel pump man enough for a mg metro turbo build ?
Its alreqdy installed in the tank so would be ideal if its man enough, im hoping for around 10 psi of boost
thanks guys *Clapping*
Iirc they only produce about 1bar of fuel pressure. So would be borderline at 10psi, & whether it can supply enough fuel to support the potential power you could make at 10psi is another question.
If it was me I’d get a proven in tank pump that way it’s one less thing to worry about or go wrong.
Phil.
shane
Member #: 1246
Lowestoft, Suffolk.
Phill is correct with the supply pressure.
I mistakingly ran an SPI one for a couple of years, it supported 150HP at 14 psi (which is more than folk law would have you believe). Asking anything more of it resulted in melted pistons which inevitably happened (more than once).
Don't cheap out on a fuel pump, its false economy.
Shane
Mr Joshua
Member #: 1954
Luton Bedfordshire
If you can get it to fit the core fuel pump for a Nissan Micra is the same unit used in The twin turbo Subaru GTb spec cars and are £35 new.
Own the day
robsturbo
Member #: 12343
mid devon
Thanks guys, im off to the dyno on the 3rd of april so i dont want any issues there if i can help it..
Ive got a brand new carb fitted with green spring, the engine is a med race engine with forged pistons bored to a 1293cc center strap crank shaft, 266 cam shaft and adjustable boost from in car..
I was aiming for 10 psi being a sensible choice for power and still be reliable car to use...
What fuel pump shall i go for ? ive heard mpi fuel pumps fit with a little modding inside the tank...
Can i run a external fuel pump bolted to the boot floor ? would it need the old pump removed from the tank to suck the fuel up ?
Not sure whats the best way to go about it all really
thanks guys
Edited by robsturbo on 9th Mar, 2024.
shane
Member #: 1246
Lowestoft, Suffolk.
An MPI will be fine for what your running and give leeway for the inevitable want of more power down the line.
Fitting one isn't tricky.
Shane
Mr Joshua
Member #: 1954
Luton Bedfordshire
the original pump can be found in most rover fuel injected cars two were fitted to the SD1. In the Metro they had there own cradle that was rubber mounted to the boot floor. I have used the pump from a ford XR3i and that worked fine. its flow that your after and the two mentioned above will give that in buckets. you could try the Pierburg as fitted to the Montego, that is good for 9psi of pressure.
Own the day
