Page: |
Home > Help Needed / General Tech Chat > K100 8V Piston cut outs required for boosted engine? | |||||||
4 Posts Member #: 12307 Junior Member |
17th Sep, 2023 at 12:09:31pm
Hi, I have tried to find this info everywhere with no success.
2629 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
17th Sep, 2023 at 08:01:10pm
The cut outs give marginal gains to total CC's, you want a little clearance for safety.
193 Posts Member #: 1297 Advanced Member Sunny Stockport |
18th Sep, 2023 at 09:16:27am
It's not just clearance at TDC that you need to look at. There's very little piston movement at TDC but quite a lot of cam movement, so clearance could be fine at TDC but you may have issues at say 20 Deg BTDC. The only way to know for sure is a dry build without a head gasket and some plasticine on the top of the pistons. Cut outs are generally a good thing as you end up with a non-interference engine, so no catastrophic events if the cam belt fails. |
19th Sep, 2023 at 11:27:36am
Yes, my intent was to modify the block myself and avoid removing the piston/conrods in the process. I don't see the point of skimming the block after adding the plugs if these are below gasket level. I agree that it makes things neat but I am trying to make this as DIY as possible, and skip as many "good to have" steps as safe to. Trying to find out where I am crossing the line...
On 17th Sep, 2023 shane said:
The cut outs give marginal gains to total CC's, you want a little clearance for safety. any reason why you are trying to avoid the cut outs? Shane |
19th Sep, 2023 at 11:35:19am
Very good point! Thank you for that. I will try this method out to find out how close I'm getting to interference. I'll try plot these relative positions on an excel too and see how bad it looks, using the cam profile shared by Paul S in this forum.
19th Sep, 2023 at 10:13:57pm
For the time it takes to remove an engine, strip it to modify and clean it post works it really isn't worth risking IMHO.
On 19th Sep, 2023 Doodoodoodadada said:
Yes, my intent was to modify the block myself and avoid removing the piston/conrods in the process. I don't see the point of skimming the block after adding the plugs if these are below gasket level. I agree that it makes things neat but I am trying to make this as DIY as possible, and skip as many "good to have" steps as safe to. Trying to find out where I am crossing the line... On 17th Sep, 2023 shane said: The cut outs give marginal gains to total CC's, you want a little clearance for safety. any reason why you are trying to avoid the cut outs? Shane Edited by shane on 19th Sep, 2023. |
Page: |
