Home > Beginners Tech > Metro turbo Garrett t3 oil return feed
Bry4ns
Member #: 12032
Great Yarmouth
Hi all ,
Anyone got any advice where to get a return oil feed pipe from (turbo to front of block )
Have brought one but the whole pipe turns when tightening up !? Have to keep running the pipe round to tighten ie not swivelled .
Thanks
DILLIGAF
Member #: 9128
https://www.minispares.com/product/Classic/...k%20to%20search
BTW this is the oil feed pipe not the return
Edited by DILLIGAF on 29th Jul, 2023.
On 29th Jul, 2023 Bry4ns said:
Hi all ,
Thanks
So is it the feed or return you want ?
The feed is a steel pipe from the oil pressure switch fitting to the turbo.
The return is a 90deg silicone type at the rear under the turbo.
The OE hard steel feed was a piece of shit and often failed, partly for the reasons you describe as it wants to turn, then gets bent when fitting. Best to make up a new one from teflon or something.
Bry4ns
Member #: 12032
Great Yarmouth
Yeah that’s the one , was just a pain in the arse trying to fit it regarding and whole pipe was turning ,, thanks for the input all
shane
Member #: 1246
Lowestoft, Suffolk.
I"ve made them in the past with fittings from Hose fittings uk.
Shane
jimmy
Member #: 829
essex
i used pirtek
1293 Turbo mini
