Home > Help Needed / General Tech Chat > Vr sensor polarity. Info share ford vs specialist components
monsterob
Member #: 11029
Crewe
Just for info .......ford vr sensor polarity for megajolt need to be reversed if you swap to specialist components sensor and trigger wheel is the other way around
I found out the hard way
Outside the box
Good info. I have upgraded to a kad damper so had to reverse the wiring too. Simon at sc mentioned it as I wouldn’t have given it a second thought as the plug is the same.
