Home > Help Needed / General Tech Chat > Help , new build engine
Bry4ns
Member #: 12032
Great Yarmouth
Hi all, just rebuilt new turbo engine due to a broken ring , one cylinder was slightly down and a bit of smoke .
So after a rebuild with new bearings , new rings , new big bearings and ruffed up cyclinders as you should ,
Getting a bit of blue/white smoke out of that exhaust and breathers , have not taken for a run yet and thought smoke would clear after a bit of time ? Have done compression test on each cylinder and they 175psi / 12bar , had the head also profession refurbed with new seals etc and pressure tested , turbo in good condition with no oil being lost etc.
loosing no oil or water and have checked head gasket and it’s good .
So ? Is , Is in normal to have smoke out of exhaust and I think it’s a bit concerning? Any advice welcome.
Thanks Bry
Rammie2000
Member #: 10190
belgium
new rings need to bed in. might be that they not seal proper yet.
Pete B
Member #: 11548
Calne Wiltshire
Are you running an intercooler did you flush it out.
Steve220
Member #: 11017
Shropshire
Rough up?? So you didn't hone it?
DILLIGAF
Member #: 9128
Plus what's in the exhaust takes ages to burn out
bpirie1000
Member #: 1793
Aberdeen,Scotland
Did the valves get any work? Check the seats?
I trust ignigtion is bang on.....
