Home > Help Needed / General Tech Chat > Gearbox
jamesRs250
Member #: 12240
Kent
How much play / endfloat should there be on the motion shaft bearing? I can't find any information on this in the Haynes manual. The other two drop gears they do give you the end float with the cover on.
This is a clip of the play I have if it helps
https://youtube.com/shorts/vAbprlKh5ig?feature=share
Thanks
shane
Member #: 1246
Lowestoft, Suffolk.
I personally would change that, and the needle roller that sit on the end of the 3rd motion shaft.
Shane
Edited by shane on 1st May, 2023.
jamesRs250
Member #: 12240
Kent
Shane
Yeah I was changing the roller bearing anyway.
Edited by jamesRs250 on 2nd May, 2023.
