Home > Help Needed / General Tech Chat > Nodiz vs dizzy on na car.
Rammie2000
Member #: 10190
belgium
Since my coil is on the way out. ( main suspect to me.. very weak spark. Engine cutted out on me yesterday in a very rainy run. Dizzy was dry. Sparkplugs dry but only gave a weak witte spar, had fuel but engine would not even start on pilot. When we pusched it to save power going to the starter engine it gave some brop brops but cut out after second or 2. The weak spark makers me suspect the coil.. its 19 years old after all.... engine ran great and Strong before)
So... i have a coilpack and nodiz with vacuüm sensor,trigerwheel,... laying around. Also have a brand New 123 dizy and coils are easy to come by.
On a na 1340
296 cam
12.3/1 compresion
Notting special realy.
Would it be usefull to get a nodiz on or would it be more work than gain to instal it vs the 123 ignition.
Keep in mind that rolling roads here are zero to non existing to get the map right so that would be me on the rond with a laptop...
Edited by Rammie2000 on 24th Apr, 2023.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Seeing as your on here I'm guessing there may be an engine upgrade or swap in its future, so go for it.
Own the day
Rammie2000
Member #: 10190
belgium
I have a turbo mini. This one stays na
Rammie2000
Member #: 10190
belgium
