Page: |
Home > General Chat > Carburettor Fuel leak | |||||||
40 Posts Member #: 10334 Member Staffordshire |
20th Mar, 2023 at 06:56:49pm
Hi guys, I'm after any advice on this one, I'm a vehicle tech with 33 years experience so not daft when it comes to engines but this friggin car is the bane of my life! I've had a bogging issue for years and I've tried literally everything to find the problem, it turned out to be the choke O rings but now I can't stop the float needle from leaking, I've replace it twice and it still leaks, I've got a fuel pressure guage coming to eliminate the pressure regulator but you can stop the fuel with mild finger pressure. Anyone else have this persistent problem? |
20th Mar, 2023 at 08:58:38pm
Sounds like excessive fuel pressure.
In the 13's at last!.. Just |
2490 Posts Member #: 1954 Post Whore Luton Bedfordshire |
21st Mar, 2023 at 08:54:24am
So by your description it sounds like you have fuel coming up the main jet and flowing into the intake manifold I would check the float needle valve is clean and in good condition. if your fuel pressure regulator was not returning you would have fuel everywhere for as you are well aware the injection type fuel pumps used in these systems can hit 9 bar. Own the day
3590 Posts Member #: 655 Post Whore Northern Ireland |
22nd Mar, 2023 at 09:11:43pm
As Josh says, the needle cannot leak persay...it is always a leak.
25th Mar, 2023 at 12:29:49pm
I've replaced the needle valve twice! The pressure gauge as just landed so I will see how that goes. |
25th Mar, 2023 at 12:29:52pm
25th Mar, 2023 at 05:11:08pm
have you made any adjustment to the paddle on the float. it could be that the needle valve isn't being closed by the float. its happened in the past Own the day
25th Mar, 2023 at 09:32:51pm
On 25th Mar, 2023 tomostrash said:
I've replaced the needle valve twice! The pressure gauge as just landed so I will see how that goes. no need to replace things at random. Test them first. apply pressure to the fuel inlet port, and raise up the float against the needle valve and test if it seals, and to what pressure 9.85 @ 145mph
27th Mar, 2023 at 09:29:14am
I've tested the fuel pressure and its 6psi |
256 Posts Member #: 11017 Senior Member Shropshire |
27th Mar, 2023 at 02:43:15pm
On 27th Mar, 2023 tomostrash said:
I've tested the fuel pressure and its 6psi Needs to be around 3.5psi. |
27th Mar, 2023 at 08:16:45pm
On idle its 7.5 but won't come down |
![]() 4629 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
27th Mar, 2023 at 08:47:52pm
Either the reg is broken, or your return line is restricted.
28th Mar, 2023 at 04:54:35pm
I've got some success!
28th Mar, 2023 at 05:39:38pm
larger return. Fix it so it can flow.
193 Posts Member #: 1297 Advanced Member Sunny Stockport |
28th Mar, 2023 at 06:11:07pm
If you've got an 8mm return then there's something wrong with it, you shouldn't get a 1.5 psi pressure drop with it and you also shouldn't get another 1.5 psi feeding into your tank. Has the pipe been crushed anywhere under the car? Are you using full bore fittings on it or fittings with a tiny hole? Any 90 degree fittings anywhere possibly? Edited by neilj1678 on 28th Mar, 2023. |
29th Mar, 2023 at 10:48:02am
Sorry to keep going on but my fuel lines are both 8mm od and I'm guessing 6mm id!
29th Mar, 2023 at 03:37:32pm
The return to the tank needs to be able to scavenge more fuel than the pump can supply thats why it needs to be of a greater bore your return line is way too small! you need 3/8" return.
On 29th Mar, 2023 tomostrash said:
Sorry to keep going on but my fuel lines are both 8mm od and I'm guessing 6mm id! I've measured the tank return on the tank itself and its 5.3mm id so I don't see how a 8mm id would benefit as the tank is a bottleneck! Edited by Mr Joshua on 29th Mar, 2023. Own the day
29th Mar, 2023 at 03:56:39pm
deleted Edited by Mr Joshua on 29th Mar, 2023. Own the day
31st Mar, 2023 at 02:47:03pm
Sorry to keep going on but my fuel lines are both 8mm od and I'm guessing 6mm id! I've measured the tank return on the tank itself and its 5.3mm id so I don't see how a 8mm id would benefit as the tank is a bottleneck! So as already said, fix the return. Doesn't matter one bit where in the return the restriction lies.....just get rid of that restriction. 9.85 @ 145mph
31st Mar, 2023 at 03:27:36pm
I fitted the pipe sizes from the metro turbo fuel tank in the end. That meant fitting the tank with two 3/8" pipes for feed and return after that I didn't need to run the resistor on the fuel pump as there was no longer the restriction caused by the tank outlet. I wanted to fit the swirl pot but just ended up fitting the strainer. It may not be what you wanted to here but my issue plagued me for over a year. When all else failed, I binned all of my fuel system broke another metro turbo and fitted everything like for like. That's when I became aware of the restriction. Your issue is its causing a fuel leak mine was fuel starvation at the pump, yours is the return line mine was the feed line. Own the day
31st Mar, 2023 at 05:14:42pm
I've now got it down to 4.5psi as the pipe in the boot had been squashed flat. After 10 years I've finally go the friggin thing running smooth, one of the fixes was the seals in the choke spool. |
1300 Posts Member #: 829 Post Whore essex |
7th Aug, 2023 at 10:16:32pm
1293 Turbo mini
Page: |
