Home > Technical Chat > turbo bulkhead box
jason050377
Member #: 12072
Gday
i am preparing the mini for paint first half of this year, the body is a mini deluxe mk1 style (external hinges) i am running the fusion fab manifold but am thinking of adding a turbo bulkhead box for more clearance and possible a Weber box again for clearence around the SC throttle body.
is this the bulk head box any good or would you recommend other
https://www.ebay.com.au/itm/CLASSIC-MINI-TU...dwAAOSwuAVW1N1~
thanks for your help guys
jason from Australia
Mr Joshua
Member #: 1954
Luton Bedfordshire
Looks to be the correct shape, but it's hard to tell due to the contrast
Own the day
Why not just make your own box ?
jason050377
Member #: 12072
after i purchase material plus my time its not worth it at 23quid
But is it right ?
One thing I hated about my box.....is the fact it is pretty flimsy steel, and you are cutting out a structural section of the bulkhead.
Now yes, the subframe likely takes a lot of the load, but if I was ever to do it again, I would use a box made of more substantial metal.
And the fact you also talk about a Weber cab style box in the upper bulkhead area....kinda makes sense to fabricate properly for your specific needs.
Steve220
Member #: 11017
Shropshire
I had this exact set up. No need for either.
I wouldn’t cut it. You should have adequate space.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Trust me it's just fine. Took a side impact bang on the A pillar everything folded around the sub frame towers, the box didn't move.
Own the day
Mr Joshua
Member #: 1954
Luton Bedfordshire
Double post
Edited by Mr Joshua on 29th Jan, 2023.
Own the day
