Page: |
Home > Technical Chat > Double Checking the brain trust RTS | |||||||
29 Posts Member #: 12072 Member |
24th Jan, 2023 at 01:54:08am
Hi Guys
2623 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
24th Jan, 2023 at 10:16:25pm
25th Jan, 2023 at 03:54:55am
thanks shane
25th Jan, 2023 at 03:55:00am
thanks shane
25th Jan, 2023 at 10:20:43pm
I have to confess I never looked for new, after purchasing a new turbo and an uprated cover I didn't want the experiment of using two 998 covers to be a costly one.
30th Jan, 2023 at 06:51:56am
Thanks Shane i have been scouring ebay uk for these 998 clutch covers but no joy any other sites you guys would recommend for second hand mini bits in the uk cheers Jason |
428 Posts Member #: 10128 Senior Member Dorset |
30th Jan, 2023 at 04:49:55pm
I'll ask a couple of the hoarders I know, someone is bound to have a stock squirreled away |
2488 Posts Member #: 1954 Post Whore Luton Bedfordshire |
31st Jan, 2023 at 10:30:22am
Might have one buried in the Shergar (once in there usually never seen again).😆 Own the day
31st Jan, 2023 at 08:44:35pm
On 30th Jan, 2023 e5tus said:
I'll ask a couple of the hoarders I know, someone is bound to have a stock squirreled away Really appreciate that, obviously happy to pay if one comes up. I was messaging Cole from classic mini DIY he said his rts is very tough to push in which used the same covers as i posted earlier so i am assuming i am after two 998 verto covers (assuming softer springs). Verto is not common like the pre verto over here |
2nd Feb, 2023 at 10:17:08pm
My engine builder Graham https://russellengineering.com.au/ who is porting the head and doing the machining is not a fan of the verto setup and believed preverto if setup correctly should be up to the task ?
2nd Feb, 2023 at 10:42:17pm
The pre verto set up is more than up to the task, but if your aiming for big HP you'd be looking at using a grey diaphragm.
3rd Feb, 2023 at 05:41:54am
thanks Shane
7th Feb, 2023 at 11:05:25am
No joy on NOS 998 covers from my local scroungers.
8th Feb, 2023 at 06:00:49am
Thanks for asking around appreciated hoping around 150 - 160 atw pre verto might be ok? |
3577 Posts Member #: 655 Post Whore Northern Ireland |
8th Feb, 2023 at 09:28:22pm
On 25th Jan, 2023 jason050377 said:
thanks shane having trouble finding these item online in particular the 998 clutch covers any suggestions? or am i just blind thanks for you help http://www.minispares.com/product/Classic/...ack%20to%20shop 9.85 @ 145mph
14th Feb, 2023 at 03:51:29am
Thanks ill go with those covers. In regards to flywheels i was talking to the machinist he is not happy with MED or Minispares taper. any one else have similar issues ? he recommended minisport or swiftune but neither do a verto flywheel from what i can see |
Page: |
