Page: |
Home > Help Needed / General Tech Chat > Ignition coil | |||||||
114 Posts Member #: 11728 Advanced Member Uden, Holland |
21st Dec, 2022 at 06:42:51pm
Because my MG Metro turbo engined mini doesn’t run well when on boost I was searching on this forum and stumbled on this topic; http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6298
3588 Posts Member #: 655 Post Whore Northern Ireland |
23rd Dec, 2022 at 03:41:20pm
I would imagine you cannot easily bolt on the wrong module to the distributor ?
2488 Posts Member #: 1954 Post Whore Luton Bedfordshire |
24th Dec, 2022 at 10:28:57pm
In my experience, the module works or it doesn't. You could be suffering from blowing out the spark. This occurs as the pressure at the point of ignition is so high the charge can't jump the gap. I would start with the plugs and dizzy cap. Make sure there Are no deposits on the contacts. You don't need all singing and dancing leads standard ones are more than ample. If the issue persists then look at the coil. Own the day
Page: |
