Home > Technical Chat > Oil return line
jason050377
Member #: 12072
Gday
I am about to get my mini gearbox build for turbo build i am doing. I recall some people drilling / taping a hole in the back of the case for the oil return / drain. I will be running gt17 of a fusion fab manifold, and already have an adapter for the oil drain that fits the fuel pump. However am i better off draining to gearbox instead or no difference.
thanks for any help
cheers Jason
Mr Joshua
Member #: 1954
Luton Bedfordshire
If you are referring to the Mechanical fuel pump then that adapter drains back into the gearbox, no need to be drilling extra holes in the casing.
Own the day
jason050377
Member #: 12072
Gday Yes its the mechanical fuel pump. just wondering if there is any advantage draining straight to gear box
Mr Joshua
Member #: 1954
Luton Bedfordshire
That is where the drain for the turbo has always been.
Own the day
There’s no reason you couldn’t go into the gearbox casing (as high as possible). But the mechanical fuel pump is a good solution that already exists.
jason050377
Member #: 12072
Great thanks guys !
e5tus
Member #: 10128
Dorset
On a GT17 setup I have that didn't need bulkhead clearance, it can't use the fuel pump location and it uses an adapted speedo housing for the drain.
wilsonc001
Member #: 11333
I plan on going into the gearbox on the new engine build, getting the GT15 into the fuel pump aperture was a nightmare - I had to make up a 'sump' to get it routed due to the angles (there's pictures of it in my 998 build thread).
