Home > Help Needed / General Tech Chat > 1380 turbo deck height
jamesRs250
Member #: 12240
Kent
What deck height should I be aiming for with my 1380 turbo?
I have 11cc omega pistons and will be getting my standard cylinder head modified for this turbo build. I'm aiming for around 15psi of boost.
Thanks
shane
Member #: 1246
Lowestoft, Suffolk.
Its dependant on CC's within your cylinder head (assume in the region of 28cc's?) and the compressed head gasket volume, also for consideration is are you using standard or lower pin height pistons?
Phil did an idiots guide on compression ratio calculation, https://www.youtube.com/watch?v=9Lp-1Rbb4Yo
Shane
Edited by shane on 22nd Oct, 2022.
Ideally you should be aiming for as little piston/deck clearance as possible. It’s not a good method to adjust CR.
Dry build. Measure the piston/deck clearance and have it machined to suit.
Why are you aiming for a specific deck height ?
IMO machine it flat, and no more.
And certainly do not have pistons running so high that they can hit the cylinder head.
jamesRs250
Member #: 12240
Kent
Cheers that video helps I'm using standard piston heights. My deck hight is 1mm. But every one say less is better.
Shane
shane
Member #: 1246
Lowestoft, Suffolk.
Having the pistons flush with the deck is preferred but by doing so will increase your compression ratio meaning you may need to gain CC's elsewhere to reduce to your desired CR (head and piston dish are the places to gain).
Shane
Shane
jamesRs250
Member #: 12240
Kent
I'm not it's just my deck height is 1mm so was asking. Going by the replies less deck height is better.
Thanks
