Page: |
Home > Help Needed / General Tech Chat > Suitable cylinder head for turbo | |||||||
79 Posts Member #: 12240 Advanced Member Kent |
29th Sep, 2022 at 08:17:12pm
Hi I have a cylinder head what has had work done years ago by minisport what they class as stage 3
3588 Posts Member #: 655 Post Whore Northern Ireland |
1st Oct, 2022 at 11:52:13am
And what does anyone perceive as a "turbo spec" ?
2488 Posts Member #: 1954 Post Whore Luton Bedfordshire |
1st Oct, 2022 at 03:04:43pm
The MG Metro head is my go to as it comes with the larger vales as standard all you really need to do is fit new valve guides, swap the exhaust valves for SS race valves and your good to go.
Own the day
1st Oct, 2022 at 06:24:00pm
The main thing I have noticed with cylinder heads modified for turbo spec are the valves are smaller size. Guessing they would be stronger because of the heat.
4th Oct, 2022 at 06:00:05pm
If your modifying it then any 1275 would do. The reason for the smaller valves is to offset the potential for the head to crack between the valve seats due to heat. Own the day
4th Oct, 2022 at 06:00:08pm
Page: |
