Home > Help Needed / General Tech Chat > 7 port / 8 port / 16v a series dipsticks
Is KAD and Specialised components the only options for these?
shane
Member #: 1246
Lowestoft, Suffolk.
The SC one is only a ford dipstick with the level notches recut to suit, the tube is merely 10mm soft drawn copper with turned aluminium ends.
A lot of money for what it is IMO.
Shane
adcyork
Member #: 6807
York
Agreed Shane, doesn’t take long to make. As long as you have a block and empty gearbox casing sat round to mark the line in the right place.
Shane
jonny f
Member #: 9894
Dorking
I have an old honda one in mine.
running up between the inlet runners.
t3gav
Member #: 229
Gavin@minispares.com
kent
MS should have some in the future for our 8 ports.
