Home > Help Needed / General Tech Chat > Which coolant and how to change all
Yoda74
Member #: 11728
Uden, Holland
The title says a lot.
I have my MG turbo engined clubman estate for four years know.
Since I have it the coolant has not been replaced.
When I look into the expansion tank I see a bit of brownish liquid, the original colour is not recognizable.
So the question is which colour should I use and what is the best way to change it all?
e5tus
Member #: 10128
Dorset
Some later rads have a drain plug, otherwise bottom hose off. I'd take the top hose off too and flush it through with water if it's manky. Coolant selection is entirely dependent on the temps you'll be running it in.
Do the exhaust clamp first before this, laying on your back in the damp fighting a rusty clamp will be less fun with antifreeze dripping in your face!
