Page: |
Home > Help Needed / General Tech Chat > What Exhaust Estate | |||||||
114 Posts Member #: 11728 Advanced Member Uden, Holland |
3rd May, 2022 at 11:33:06am
Hi guys,
3rd May, 2022 at 06:03:18pm
A few pics from the current exhaust.
4th May, 2022 at 10:28:59am
I have only ever had Playmini and Maniflow on my cars. Both are great but prefer Playmini to be honest, everyone of them has fitted faultlessly and if they are still making them that would be my choice.
Edited by wolfie on 4th May, 2022. Crystal Sound Audio said:
10 Posts Member #: 12185 Member |
4th May, 2022 at 11:38:03am
I have a playmini system. They do a specific LWB back box |
4th May, 2022 at 12:15:22pm
Thanks Wolfie,
Edited by Yoda74 on 4th May, 2022. |
4th May, 2022 at 12:17:34pm
@Hazpalmer, what do you mean with LWB? |
2094 Posts Member #: 9894 Post Whore Dorking |
4th May, 2022 at 05:07:42pm
LWB = long wheel base, aka pickup , traveler and estate. |
4th May, 2022 at 06:34:58pm
Ofcourse….I could have guessed that… |
264 Posts Member #: 11029 Senior Member Crewe |
8th May, 2022 at 04:21:57pm
Ive got a maniflow on mine with the smaller back box no mid box as the turbo keeps it quiet Outside the box |
8th May, 2022 at 06:38:35pm
I e-mailed Maniflow for a solution, got a reply, but communication goes very slow….
108 Posts Member #: 9182 Advanced Member |
9th May, 2022 at 03:32:56pm
I ran a Maniflow twin box LWB on my Estate and it fitted really well. On my Turbo I run a RC40 twin box and its nice and quite. Because you have the turbo flexi joint you can cut the pipe to the required lenght and than you just have to extend the rear if you use a standard exhaust. |
12th May, 2022 at 02:12:21pm
@viz139: I think the downpipe is 2" diameter? At he Maniflow website I don't see a full 2" 2 box system for LWB, only a 1 3/4"
14th May, 2022 at 02:15:44pm
Ring Maniflow they are far better communicating over the phone. Tell them what youre after and they will make you something to your requirements. they did for me.
Outside the box |
18th May, 2022 at 09:57:49pm
I know Maniflow do a large 2" turbo downpipe but I think the standard one is 1 3/4". Its a while since I did it but I'm pretty sure the RC40 went straight on. |
22nd May, 2022 at 08:25:23pm
I made some more pictures.
5th Jun, 2022 at 10:29:41am
I’ve measured the bend from the downpipe and it seems even less than 1,75”. Maybe in the bend is not the best place to measure….
428 Posts Member #: 10128 Senior Member Dorset |
6th Jun, 2022 at 07:06:12am
On 5th Jun, 2022 Yoda74 said:
I looked up from below and see that the top clamp is hard to reach. What’s the best way to reach for it? It is a pain, no way around that. I wrap my arm in cling film to reduce the cuts, abrasion and exhaust wrap irritation. Depending how it's oriented you might need to remove stuff from engine to attack from above, or lay on your back and struggle. Looks to be rusty, soak it with WD40 first and hope it comes off cleanly. New one, few tricks here: - match the exhaust and turbo outlet sizes for better sealing to avoid using sealant - weld the bolts into one half of the clamp - use long brass manifold nuts Good luck! |
11th Aug, 2022 at 06:13:49pm
Maniflow can make a full 2” 2 box system including new turbo downpipe.
256 Posts Member #: 11017 Senior Member Shropshire |
11th Aug, 2022 at 09:11:08pm
I went for a custom full stainless 2.25" system with an ST3 manifold. All done by Fusion Fabrications.
12th Aug, 2022 at 04:33:25am
Looking good.
12th Aug, 2022 at 09:45:01am
On 12th Aug, 2022 Yoda74 said:
Looking good. What is the sound like? Not (too) loud? Engine isn't even fitted yet. Edited by Steve220 on 12th Aug, 2022. |
12th Aug, 2022 at 10:06:41am
Ah, nice and quiet .... 😁 |
18th Aug, 2022 at 06:36:06pm
On 11th Aug, 2022 Yoda74 said:
Maniflow can make a full 2” 2 box system including new turbo downpipe. In mild steel or stainless (only outside?) Downpipe only available in mild steel. Will a larger 2” system fit nicely near the shifter? Will a stainless system be louder than a mild steel one? It must not be loud. What’s your opinion? |
Page: |
