Page: |
Home > Technical Chat > Plenum design | |||||||
1st May, 2022 at 11:58:50am
2623 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
1st May, 2022 at 05:16:11pm
For my K build I originally had a Semi circular log type plenum with the throttle body at one end, I sent the Car to Clare and Bob at Concept racing for an intercooler to be fabricated and the feedback from Bob was the design was poor and advised that the shape should be tapered to promote flow to the furthest cylinders from the throttle body.
Edited by shane on 1st May, 2022. |
3577 Posts Member #: 655 Post Whore Northern Ireland |
1st May, 2022 at 07:43:27pm
If it's a boosted plenum, I wouldn't worry too much.
1st May, 2022 at 08:09:10pm
EFI
14th May, 2022 at 03:40:02pm
Mine is single TB and in from one end.
7 Posts Member #: 12326 Junior Member |
26th Dec, 2023 at 11:29:48am
when I built mine I used a flat alloy plate with the 4 holes in for the trumpets to hold the plenum chamber onto the throttle bodies then I welded the sides on with the blown air on one side and the blow off valve on the other side then bolted the back plate onto the box with a gasket |
Page: |
