Page: |
Home > A-Series EFI / Injection > Fuel Pressure reg | |||||||
20th Feb, 2022 at 11:41:55am
Where have you mounted your fuel pressure reg? Crystal Sound Audio said:
4625 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
20th Feb, 2022 at 02:13:07pm
Injection? Or still on the carb mate?
20th Feb, 2022 at 06:28:54pm
Injection Phil.
3588 Posts Member #: 655 Post Whore Northern Ireland |
21st Feb, 2022 at 08:02:38pm
Typical for a full flow rail install, the reg will be mounted after the rails.
2629 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
21st Feb, 2022 at 11:39:07pm
For my K Build I mounted direct to the rail, but initially it was remote.
22nd Feb, 2022 at 12:02:08pm
On 21st Feb, 2022 shane said:
For my K Build I mounted direct to the rail, but initially it was remote. Shane Crystal Sound Audio said:
22nd Feb, 2022 at 10:37:05pm
On 22nd Feb, 2022 wolfie said:
Initially i thought the same but the under bonnet clearance on the 7 port is minimal. On 21st Feb, 2022 shane said: For my K Build I mounted direct to the rail, but initially it was remote. Shane |
24th Feb, 2022 at 05:12:37pm
I will probably use something small like the jenvey or webcon ones.
26th Feb, 2022 at 01:44:50pm
Generally you put the regulator at the far end of the fuel rail so the set pressure is delivered to all the injectors and the rest just spilled back to the tank after the fuel rail. Schrödinger's cat - so which one am I ??? |
Page: |
