Home > General Chat > Putting mini Taper bearings in metro hubs?
TurboDave16V
Is this a straightforward installation or am I likely to need to play with the shimming to get them just right?
I'm sure I knew this answer 20 years ago, but that was getting on for two decades, which is a long time!
*happy*
Mr Joshua
Member #: 1954
Luton Bedfordshire
It should be a straight swap only had 1 mini with taper rollers in the rear hubs. Everything else should be a parts bin special
Own the day
straight swap, done this loads of times
