Page: |
Home > Help Needed / General Tech Chat > what pistons | |||||||
8 Posts Member #: 12109 Junior Member |
1st Feb, 2022 at 11:56:45am
i know this is an old subject but are 18cc forged omegas worth the extra money, and will cc be too low will need to buy a set to see if too low in bore. or better going for cast 10cc that apparently sit higher |
855 Posts Member #: 951 Post Whore Bromsgrove |
1st Feb, 2022 at 03:21:50pm
I think it depends on what power you want to run. If you are aiming for the moon you need forged pistons and a CR around 8.5. If you haven't yet worked on the cylinder head you may be able to compensate for the larger piston bowl size. 'Where does the engine go?' |
1st Feb, 2022 at 04:24:00pm
head already done, running gt17 with intercooler and aiming around 140. as said can work out but that would mean buying pistons first to work it out. was planning originally omega forged but now worried re. 16cc dish |
4625 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
1st Feb, 2022 at 07:42:14pm
The cast Omegas will be more than adequate for 140hp.
2629 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
3rd Feb, 2022 at 06:47:48pm
The Omega casts can have the dish opened out slightly, SC took mine to 16cc for my K build.
4th Feb, 2022 at 12:30:40pm
thanks for info go for cast then |
6745 Posts Member #: 828 Post Whore uranus |
5th Feb, 2022 at 11:27:33am
i am using cast omegas .
10020 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
6th Feb, 2022 at 10:28:49pm
Forged are more forgiving but unless you are chasing the moon I'd just go with tried an tested Cast Omega's If something is worth doing, it's worth doing half of. |
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
12th Feb, 2022 at 08:08:15pm
cast omegas get the thumbs up from me
Yes i moved to the darkside
Page: |
