Home > Wanted > Turbo parts
bigfootandy
Member #: 12207
Hi, I’m after a complete turbo setup, manifold, turbo, inlet, carb oil feed etc. Has anyone got anything?
Cheers Andy
tadge44
Member #: 2500
Buckinghamshire
That is going backwards Andy, after you gave up on turbos
bigfootandy
Member #: 12207
Well this year is the 25th anniversary of my last effort and I’m reliving my youth… call it a midlife crisis!!
Edited by bigfootandy on 28th Jan, 2022.
tadge44
Member #: 2500
Buckinghamshire
I remember that so well with you searching for plugs at a rally as you had burned them
all out with uncontrolled boost
Mr Joshua
Member #: 1954
Luton Bedfordshire
Do you want it all bolted to the head or separate
Own the day
bigfootandy
Member #: 12207
It wasn't uncontrolled boost Dave, knackered fuel pressure regulator, I did however increase the boost massively after a trip to the GWR at Bowood house, that resulted in a melted piston about 500 yards from my workshop!
