Page: |
Home > Help Needed / General Tech Chat > Choose transmission | |||||||
3 Posts Member #: 12200 Junior Member |
5th Jan, 2022 at 07:22:27pm
I am in the middle of an engine build and need transmission advice. The engine will most likely produce a lot of torque (big bore, X-flow, supercharged, fuel injected etc.) and is intended to be used on the street. Used block is a 1275 pre A+ one and to it I have the corresponding clutch housing, gearbox, transfer gears and so on. Except from that I have a DAM 5626 gearbox housing with an unused Jack Knight SCCR gearset on the shelf. I think I can live with the whining on the first three gears and would preferably stick to helical transfer gear. (Out of what I have read it should be doable as long as I am driving with my brain)
3588 Posts Member #: 655 Post Whore Northern Ireland |
5th Jan, 2022 at 09:25:02pm
The block doesn't care which box or housing you use, so not much to worry about there.
2629 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
5th Jan, 2022 at 10:03:13pm
Im currently running SC gears and helical drops without issue and significant power.
6th Jan, 2022 at 09:50:10am
Thank you for your opinions @stevieturbo and @shane. Any preferences considering choice of clutch housing (pre A+/A+), i.e. should I aim for the larger idler gear shaft and bearing (A+)? |
256 Posts Member #: 11017 Senior Member Shropshire |
6th Jan, 2022 at 11:56:38am
On 6th Jan, 2022 Java_Green said:
Thank you for your opinions @stevieturbo and @shane. Any preferences considering choice of clutch housing (pre A+/A+), i.e. should I aim for the larger idler gear shaft and bearing (A+)? Yes, alone with the larger first motion bearing. |
6th Jan, 2022 at 01:10:58pm
The idler gear needs to match the gearbox and then the drop gear housing needs to match the idler gear.
6th Jan, 2022 at 10:28:56pm
As Per Grahams response with the 7|8" idler bearing over the 3/4".
8th Jan, 2022 at 10:00:57pm
you need to use the housing to suit the idler gears and bearings in use. 9.85 @ 145mph
Page: |
