Home > Help Needed / General Tech Chat > Map settings for Aldon Amethyst
sam138
Member #: 10219
Just wondering if anyone uses the Aldon Amethyst on here and if they could help with a base map setting to get my 1275 supercharger started and running before rolling road ?
It’s a suck through set up running 8-9psi.
I’ve set the static timing at 5 degrees BTDC as per the Hayes manual to hopefully enable the car to start and locked the mechanical advance as per instructions.
Amethyst unit has an offset option which I believe I input the 5 degree initial advance into.
Any help would be much appreciated.
Edited by sam138 on 23rd Oct, 2021.
Jonny_A
Member #: 12176
Sorry can’t answer the question but I’ll be following this as I am looking into which Mappable Ignition to get and like the Amethyst.
