Home > A-Series EFI / Injection > SPI none start 1995
jimmy
Member #: 829
essex
Hi All
Long time no speak i have a 1275 SPI mini not start you can put fuel down the inlet turn the engine over and it starts i have no power output from the brown/grey wire on the cut off fuel switch which is on the n/s next to the rad if i put power to the brown / grey wire it will fire up the pump but when you crank the engine over it still not starting i have replaced the relay unit (little black box) and replaced the fuel pump about 8 weeks ago any one got any idear
1293 Turbo mini
e5tus
Member #: 10128
Dorset
When you power the pump you are getting fuel at inlet?
As above, does the pump actually pump and pressurise the system when you power it up ?
I once had an SPi Metro where the pump would show 12V but got clogged up internally so didn't actually flow any fuel.
I don't know how they fit in the tank in the Mini but in the Metro I had to cut a circular hole in the boot floor to take it out if the tank - the recess was clearly pressed into the boot floor but Leyland never actually made it a sealed openning, just solid metal....
Dismantling the pump was a pain, the end was O-ring sealed but crimped in place but once open, it was just corrosion from the steel parts of the motor windings that were causing it to stick (damp petrol ? as the motor runs in the fuel).
jimmy
Member #: 829
essex
i have got to the bottom of it i had a spark and i had fuel but would not start it turned out to be the injector (SPI) model had stopped work what i did was remove the black plug and wired a LED lamp to the black plug on the loom so when you cranked the engine the lamp flashed so i removed the injector to find it was blocked with shit blow out with air line put it all back turn the key and it started straight up *Clapping*
1293 Turbo mini
