Page: |
Home > Help Needed / General Tech Chat > 5/16th block/gearbox mod | |||||||
18th Sep, 2021 at 11:18:17am
Is it still worth doing doing the 5/16 bolt mod between engine and box?
2094 Posts Member #: 9894 Post Whore Dorking |
18th Sep, 2021 at 12:50:43pm
What would be the reason not to?
2629 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
18th Sep, 2021 at 09:12:07pm
For how easy it is to dots a no brainer.
5417 Posts Member #: 6181 Double hard bastard brookwood woking |
19th Sep, 2021 at 07:46:57pm
I have never done it lol
10020 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
20th Sep, 2021 at 09:15:29am
I think Dave used to sell some uprated cap-heads and hardened washers. I used to run those. If something is worth doing, it's worth doing half of. |
4304 Posts Member #: 1321 Post Whore Wiltshire |
20th Sep, 2021 at 09:43:29am
I did it because a long established engine builder told me to! On 7th Oct, 2010 5haneJ said:
20th Sep, 2021 at 10:50:50am
I just used good grade 1/4unf bolts and nice sized washers all was good 👌
2488 Posts Member #: 1954 Post Whore Luton Bedfordshire |
20th Sep, 2021 at 09:43:45pm
I swapped to bi-hex bolts the same as used on the jet pipes of gas turbine engines due to access on tightening. Edited by Mr Joshua on 20th Sep, 2021. Own the day
428 Posts Member #: 10128 Senior Member Dorset |
21st Sep, 2021 at 09:46:02am
I wasn't aware of this, makes complete sense. Will add to the list next time there's a need to split block and box. Always learning! |
21st Sep, 2021 at 04:54:28pm
https://www.ebay.co.uk/itm/183773005074?has...ncAAOSwrv5cimpV
Own the day
1750 Posts Member #: 10190 Post Whore belgium |
22nd Sep, 2021 at 07:54:04pm
Why? How much force can there be between those 2 that it needs additional strength.?? you can do anything if you set your mind to it...
Page: |
