Page: |
Home > Help Needed / General Tech Chat > Door skin | |||||||
61 Posts Member #: 10810 Advanced Member Kent,medway |
27th Aug, 2021 at 06:56:15pm
Evening, Iv been offered a set of doors. Ones had the skin and bottom piece done the other is stripped and ready to have the bottom piece and skin done. Never done one before and a bit nervous but it’s a couple hundred quid cheaper than ones already done. Any advice or tips?
28th Aug, 2021 at 09:31:42am
The repair section depending on which version/make you use, is relativelty easy if you are OK with welding (and have a decent welder) but be carefull to make sure the final door frame height is correct before welding. Because most repair sections have the round ends and connect on the vertical part of the frame it's easy to mess up the overall height.
Forum Mod 5933 Posts Member #: 784 9 times Avon Park Class C winner Milton Keynes |
30th Aug, 2021 at 06:40:43am
Take measurements top to bottom of the frame before cutting any metal away for reference of fitting the new section. After welding the new section in place test fit it in the car to be sure its ok.
I seriously doubt it! |
30th Aug, 2021 at 07:12:35am
Thank you. Appreciate the advice |
Page: |
