Page: |
Home > Technical Chat > Wanted turbo mini metro parts wanted | |||||||
13 Posts Member #: 12129 Member Northern Ireland |
1st Jun, 2021 at 09:43:26pm
So I've got a bare metro turbo engine for my restoration.
If you don't own one you will never understand.... |
1 Posts Member #: 12137 Junior Member |
13th Jun, 2021 at 04:53:45pm
Hi mate
1648 Posts Member #: 9038 Post Whore Carlisle, Cumbria |
14th Jun, 2021 at 09:29:48am
Turbo inlet is different. You need one that will clear which ever exhaust manifold you're using. Exhaust wise any 2" system will be good. Turbo wise the T3 is quite old tech now not that it won't do the job. The GT1752 is a nice modern alternative and is good for 200hp. Metro turbo final drive is 3.2 diff ratio depends on what you what the car for. I'm using a 2.9 some use a 3.1,3.2 or 3.44
14th Jun, 2021 at 09:29:52am
3577 Posts Member #: 655 Post Whore Northern Ireland |
16th Jun, 2021 at 09:58:54pm
Really....you'd be better getting one of the fabricated turbo manifolds that allows a small turbo without the cutting of the bulkhead.
19th Jun, 2021 at 10:26:57pm
Thanks so much for advice.
19th Jun, 2021 at 10:37:54pm
Sorry when I asked about inlet manifold would a lcb manifold work like a fletcher one.
20th Jun, 2021 at 09:11:57am
If you use a metro turbo exhaust manifold, you must use the metro turbo inlet manifold.
Edited by stevieturbo on 20th Jun, 2021. 9.85 @ 145mph
23rd Jun, 2021 at 06:15:07pm
Thanks. Much appreciated. I've just bought original metro one now and I can get original t3 exhaust manifold soon as one comes up. If you don't own one you will never understand.... |
Page: |
